2wd m50d-r1 to 4wd tailhousing - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 4th, 2010, 05:01 PM   #1
93BajaRanger
93BajaRanger's Avatar
Default 2wd m50d-r1 to 4wd tailhousing
I have researched a little bit and I believe that it is possible. Just wanting to confirm this and/or deny this. Thank you for your help.
93BajaRanger is offline   Reply With Quote
Old March 4th, 2010, 07:27 PM   #2
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
Technically, yes.
The output shafts are different lengths. They should be the same spline count. I do not know if simply cutting a bit off the end would suffice (OR which one is shorter/longer). More often than not I am told to replace the 2wd output shaft with a 4wd one (which requires disassembling the transmission).
But everywhere I've heard, you will run into some kind of output shaft length issue.
Old March 4th, 2010, 10:29 PM   #3
93BajaRanger
Thank you for your help. I am doin a sas swap on a 2wd ranger and seein what i can use.
Old March 5th, 2010, 03:26 PM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
the 4wd output shaft is longer, if i remember right it is around 3" longer
Page generated in 0.18160 seconds with 35 queries
