94 jimmy sfa - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 5th, 2010, 03:24 PM   #21
Jeepaholc92
Jeepaholc92's Avatar
very nice
Jeepaholc92 is offline   Reply With Quote
Old May 9th, 2010, 09:47 PM   #22
OL RED
workin hard to play hard
OL RED's Avatar
Send a message via Yahoo to OL RED
been working on building the 203 205 doubler adapter and modifing the 205 shift rails so the most i have done is patching the gas tank and getting the dash finished up. here a few pics.
OL RED is offline   Reply With Quote
Old June 24th, 2010, 09:04 AM   #23
OL RED
OL RED's Avatar
got a dana 60 under it and the motor mounted. decided to just buy the doubler adapter so im waiting for that to come. i think its going to be a waiting game for parts and funds now.
heres some pics
Old June 24th, 2010, 06:38 PM   #24
Jeepaholc92
ready by 2nd week of july? or ya gunna take your truck out?
Old September 19th, 2010, 06:43 PM   #25
OL RED
OL RED's Avatar
well its been a while since ive posted. got the doubler in most everything drivetrain related mounted up. working on tie rods but on of the ends was bent so ive got to wait for the replacement to arrive. and find a flat pitman arm to fit with an astro van box. also got a nice set of 38's for it. just need to get someone over here to wire it up for me.
Old September 19th, 2010, 06:59 PM   #26
drew91xj
drew91xj's Avatar
looking good cant wait to see it done
Old September 19th, 2010, 07:11 PM   #27
Jeepaholc92
x2
Old January 6th, 2011, 10:03 AM   #28
OL RED
OL RED's Avatar
well i havent gotten a ton done got a little demotivated after pulling the d60 cover off. although i do have the rock sliders welded on and a front drive shaft made working on the rear. anyways heres the pics
busted 60 carrier
picture of the mess i have going
rock slider
i think its time to clean the garage
Old January 6th, 2011, 10:22 AM   #29
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Just Lincoln lock the front up
Old January 6th, 2011, 12:29 PM   #30
OL RED
OL RED's Avatar
i would but theres only half a bin there both sides of the carrier are wopped out like that. so im thinking since the gears need replaced due to chunks missing ill buy gears and maybe a detroit.
what really pisses me off is i bought it from a cousin who said it was ready to go. since no chunks fell out of it when i opened the cover, im pretty sure he knew this is was shot when he charged me $700 for it.
Old January 6th, 2011, 12:49 PM   #31
Windsorf350
Rusty Racing
Windsorf350's Avatar
get ahold of bigblockford79 he has a 35 spline dana60 open carier but its a ford i dont know what 60 you have chevy or ford and im not sure if chevy and ford are the same
Windsorf350 is offline   Reply With Quote
Old November 7th, 2011, 08:38 AM   #32
OL RED
OL RED's Avatar
havent updated this in a long while. ive got most everything done just running into snags. The first is that the motor runs like crap and i am working with scooter to see if he can straighten it out.
the second is that no matter how or how long i bleed the brakes they always have air in them. would this be from a bad master cylinder or booster?
then all i have to do is finish mounting the shift levers for the doubler and take it for a test ride.
Old November 21st, 2011, 10:33 AM   #33
OL RED
OL RED's Avatar
well scooter called last night he's got it runnin. just need to finalize road testing and i can go pick it up! then ill figure out the heater and take it for a test run at rocks and valleys
oh and if anyone ever needs programing work scooter is the man to get ahold of. he really knows his stuff.
and just cuz im excited
Old November 27th, 2011, 11:40 PM   #34
Jeepaholc92
hell yeah!
Old November 29th, 2011, 11:20 AM   #35
OL RED
OL RED's Avatar
scooter is still triing to work the kinks out, so by the sounds of it i will either be doing a cam a head swap on the motor thats in it or building a different one.
still hoping to drive it through rocks and valleys this december.
Old December 20th, 2011, 11:00 AM   #36
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
LOL - had no idea this was going on behind my back.
@clarkstoncracker
Old December 20th, 2011, 11:25 AM   #37
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
So, I saw Derek's post in general tech about what heads and cam would be good for a TBI motor - said he had it at a garage and they told him he needed to change those two things before it would ever run right. I think it's the same folk that sold him that janked D60...
Somehow, I talked Derek into bringing this down to me to fix, so I've had it for - what- damn-near a month now (damn day job!). So here's a rundown of the problems he had & why it wouldn't run:
1. Someone sold him a TBI computer for a 350; in reality, it was for a 4.3L V6...
2. Repair shop never adjusted the throttle setscrew & TPS voltage correctly;
3. Someone forgot to hook up a stray vacuum line...
4. The cam is inappropriate for a stock TBI computer;
5. Derek has some bad mf'in luck sometimes.
After getting the right base calibration for his computer, I set to changing the VE tables for fuel. This thing has a lumpy cam in it - nothing serious as far as duration and lift, but the lobe separation angle is somewhere around 105 degrees. Lots and lots of valve overlap to mess with the MAP signal -AND- there's so much internal EGR from the narrow LSA, the damn thing just plain don't like to idle for the TBI setup.
Nobody knew the specifics, so I threw a dial indicator on the rocker arms and figured out the cam's basics.
I got most of it straightened out, but the (old) age of the computer didn't let me read the ECU data fast enough (one sample, roughly every 2 seconds SUCKS!). I grabbed a newer computer, disassembled an old unit for the sockets - and built a translation harness so I could hook up the newer computer to the older harness. The newer computer uses better software and has a much higher bus speed - it lets me take data at 10hz.
Now, here's where the problems began.
I'm using a hardware setup that lets me emulate the calibrations on the processor and make real-time calibration changes. Well, turns out, mine slowly died in the process of converting over to the new computer, so I spent a week diagnosing problems that don't exist. I'm waiting to send it back for repair, but for now, it's the only way I can take data & post-process it. From there, I burn the new calibration to a chip and got back outside and test. Having the emulator malfunctioning creates about 10x the work needed just to get a functioning calibration.
Anyway, I'm back out in the truck and calibrating daily after work and getting it zeroed in - biggest hurdle left is to pull all of the wires out of his harness connectors and repin them to the connectors in the new ECU. LOL - it wouldn't be so bad, except this damn Jimmy is TALL! I have a permanent bruise on the back of my left leg from hopping in and out.
Things look well for being done by Friday - just remember - I want to get back out in it at the mounds or somewhere offroad so I can verify everything runs as it should.
@clarkstoncracker
Old December 20th, 2011, 12:27 PM   #38
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
and of course - since I work on this thing in my driveway, the heater works now.
@clarkstoncracker
Old December 20th, 2011, 12:44 PM   #39
OL RED
OL RED's Avatar
thanks a million again scooter! sorry about the bruises we shall set up a time to meet at the mounds, for some wheeling/calibrating fun.
so with all that being done alls im really gonna have to do is weld the floor back up, and clean it up. oh and wheel it.
Old December 20th, 2011, 08:26 PM   #40
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Got it repinned with new connectors tonight and got rid of the adapter harness I made - but I ran out of fuel.
@clarkstoncracker
Page generated in 0.45795 seconds with 83 queries
