8.8. weld it or run the factory trac lock? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2010, 12:42 PM   #1
caveman
GeoDude
caveman's Avatar
Default 8.8. weld it or run the factory trac lock?
my axle seal in my xj is leaking and rather than put money into it i'm going to upgrade to a 8.8. the local junkyard has about half a million exlplorers and i'm sure i have my choice of any gear ratio, disc or drum, and open or factory l/s
it's a xj daily driver on 36's. currently welded and doing fine. i don't want to not weld my rear and have it screw me over from doing an obsticle by not locking both my rear tires.
Old March 3rd, 2010, 12:52 PM   #2
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
The one I have has a mini spool in it and does real well so far. I'm just trying to figure out how to get the new disk breaks hooked up.
lastmanstandin is offline   Reply With Quote
Old March 3rd, 2010, 12:56 PM   #3
xj97sport
atv rider
xj97sport's Avatar
l/s if its a dd weld it or mini spool it if its a toy, i did l/s on my xj and never had any issues
Old March 3rd, 2010, 01:00 PM   #4
Billaksblazer
Billaksblazer's Avatar
you can rebuild the trac lock and change the pattern of steel and fiber disks to make it lock up tighter. also you can use a ford lightning preload spring to make it tighter also.
Billaksblazer is offline   Reply With Quote
Old March 11th, 2010, 09:05 PM   #5
pigfat
GONE COMMANDO
pigfat's Avatar
anytime you weld the spider gears in a diff you change the metalurgical properties of the metal. After you apply that much heat to it you weaken it and give it a tendancy to break under heavy load. Ive seen the diff carriers break after welding and also you have to watch the spatter amount that ends up in the axle. Get a mini spool that way your not putting any heat to your components and achieving the same desired outcome and its safer.
pigfat is offline   Reply With Quote
Old March 15th, 2010, 01:55 PM   #6
Fraser
Fraser's Avatar
really? haven't heard of that one before. wouldn't happen to have a part # on that would you?
Old March 15th, 2010, 04:32 PM   #7
Billaksblazer
hmm no. the last time i rebuilt one of those was 3-4 years ago. i remember reading it on a mustang site.
Old March 16th, 2010, 04:11 AM   #8
Fraser
Fraser's Avatar
ah, ok
Old March 16th, 2010, 07:49 AM   #9
Billaksblazer
your ford dealer should have the part number. thats where i got all the parts.
Page generated in 0.24748 seconds with 50 queries
