will it bolt on - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2010, 06:35 PM   #1
littleharv93
big bad exploder
littleharv93's Avatar
Default will it bolt on
hi how easy will a dana 44 and ford 9 inch be to swap out in my explorer the current axles are dana 35ttb and ford 8.8
will i need to fab anything
will drave shafts hook up
the new axles hopefully are out of a 79 bronco
littleharv93 is offline   Reply With Quote
Old March 1st, 2010, 06:56 PM   #2
masterbeatty
masterbeatty's Avatar
you will need to set up steering, a trac bar, radius arms or leaf spring it, shock mounts.
i am thinking that you will need to either get a external vss setup if its an auto, what year is the explorer. it really isnt hard just alot of little fab work has to go into it. seriousexplorations.com has alot of info.
Old March 1st, 2010, 07:29 PM   #3
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Your driveshafts will not work either, the U-joint on the front will be quite a bit smaller that the D44 and your year shaft uses a flange mount most likely and will also need changing. I swapped the same axles into my 93 ranger and there is quite a lot of fab work to do the job cerrectly and have it work well offroad.
Old March 2nd, 2010, 06:21 PM   #4
95Bronco
Why do it though? Properly setup a TTB can be set up plenty flexible for around here.
The 8.8 isn't giving up much at all to the 9".
It just isn't worth the hassle. Swap 44 knuckles for bigger brakes and hubs onto the 35 front, and then you could swap aftermarket shafts into the 8.8. You could change the rear pattern to 5x5.5 to match the front, and upgrade to 31 spline when you change the rear shafts.
95Bronco is offline   Reply With Quote
Old March 21st, 2010, 01:05 PM   #5
lovebite
BAMF
lovebite's Avatar
Explorer forum... pretty sure you will find someone that has already done this and has pictures of the build and most relevant information.
Explorer/Ranger Solid Axle Swap Registry - Ford Explorer Ranger Enthusiasts "Serious Explorations"
lovebite is offline   Reply With Quote
Old March 22nd, 2010, 02:46 PM   #6
littleharv93
big bad exploder
can i use a ford bronco 2 lift kit to lift the explorer 4 inches
i am going to keep the front axle too thanks for the input
Old March 24th, 2010, 03:45 PM   #7
littleharv93
big bad exploder
bump i need to know theres a good deal on the bronco 2 lift
Old March 25th, 2010, 09:45 PM   #8
lovebite
BAMF
lovebite's Avatar
http://www.explorerforum.com/forums/...=bronco+2+lift
and
http://www.explorerforum.com/forums/...en+bronco+lift
yes, but would you want to?
Old April 4th, 2010, 07:59 PM   #9
Rulebreaker
Cadillac Jeeper/ RPM
Rulebreaker's Avatar
+1
Call it dumb luck but I never broke a D35 or 8.8 part, but I could fill a trash can with all the D44 and 9" parts that I have broke over the years. In fact I just broke a stub shaft on my Aerostar last weekend for like the 6th time. RB
Rulebreaker is offline   Reply With Quote
Old April 4th, 2010, 08:10 PM   #10
Freak
Wheelin the HD
Freak's Avatar
Originally Posted by Rulebreaker View Post
+1
yep I'm on my 2nd 44 stub.
Old May 20th, 2010, 09:42 AM   #11
89cjwftw
jeeprbrown
89cjwftw's Avatar
i agree, the d35 has plenty enough flex for places around here.
89cjwftw is offline   Reply With Quote
Old May 21st, 2010, 01:11 AM   #12
Never_Evil
+1
With the Aerostar being a ranger based vehicle, the axle on the front should be a dana 35. Kind of a contradiction.
Page generated in 0.34311 seconds with 60 queries
