Lt1 v8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2010, 06:44 PM   #1
MJ_Silver_1988
MJ_Silver_1988's Avatar
Send a message via AIM to MJ_Silver_1988
Default Lt1 v8
I am looking for an OBD1 LT1 V8. I need it complete with alternator water pump power steering pump wiring harness and everything. I will be putting it in my Cherokee so i need everything. I will also be looking for a low mileage 700r4 to put behind it. Let me know what you have, how many miles are on it and how much thanks.
MJ_Silver_1988 is offline   Reply With Quote
Old March 2nd, 2010, 10:16 AM   #2
95Bronco
Any interest in the Impala engine? Same style a little less power maybe even iron heads. Reverse cooling with front mount distributer.
Don't know anything at all about it but could try and get the guys number for you.
Watch out for the optispark distrubuter on those. They fail. Regularly. You probably already know that though. They are good motors. I had one and did a bunch of work to it/with it a few years back.
95Bronco is offline   Reply With Quote
Old March 2nd, 2010, 10:36 AM   #3
MILKTOST
Flexes like a bulldozer
MILKTOST's Avatar
I ve got a 1996 lt-1, complete. I have every bracket combination
possible for this engine, vette, camaro impala ss, caprice with HD cooling
(mechanical cooling fan), It is currently in my Jeep,carbed with a GMPP
intake manifold, it was installed last spring, engine had approx 52K on it. Bought it from LKQ if I remember right. I've got the yard label somewhere with the vin# and mileage of the car. I've also got 3 boxes of spare optispark units, 1st and 2nd design, prolly 6 or 7 water pumps of different designs, plug wires, all kinds of spare stuff! Ive got obd1 and obd 2 ecu's, uncut
harness, and one cut harness (but all efi connectors are there)
I also have a 4 bolt main corvette Lt-1 with hot cam kit installed, ran like
a mother! spins 7,200 rpm no problem with a carb on it, but it smokes,
needs to be re-rung, also have a Impala ss Lt-1, spun a rod. I have
replacement crank and rod for it, needs to be gone thru.
PM me and I'll make a package deal for all of it!
I'll throw in a set of shorty headers and NIB D-port header flanges
so you can mod headers to fit.
MILKTOST is offline   Reply With Quote
Page generated in 0.13991 seconds with 32 queries
