1979 Ford Dana 60 r ***SOLD*** - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 1st, 2010, 04:45 PM   #1
snodevil
snodevil's Avatar
Location: Berkley, MI 48072 / Indian River, MI 49749 (cottage)
Send a message via AIM to snodevil Send a message via MSN to snodevil
Cool 1979 Ford Dana 60 r ***SOLD***
Rear low pinion 60 out of a 79 ford 250. It is full size at 67" wms and full float with 30 spline shafts, open carrier and 3.54 gears. This is a complete stock axle with drums, spring perches and all still on it.
Axle tag reads: 354 d8ta 603901-2
$150
SOLD!
http://i178.photobucket.com/albums/w...1/PIC_0137.jpg
http://i178.photobucket.com/albums/w...1/PIC_0138.jpg
http://i178.photobucket.com/albums/w...1/PIC_0139.jpg
snodevil is offline
Old March 21st, 2010, 04:34 PM   #2
chuckyingle
do you still have it and can you send me a pic
chuckyingle is offline
Old March 22nd, 2010, 05:01 AM   #3
snodevil
snodevil's Avatar
Yup, still here!
I'll try and get a pic asap.
Edit: pics up
snodevil is offline
Old March 30th, 2010, 04:58 PM   #4
spiderman32
GETTING THERE
spiderman32's Avatar
Default axle
why are you getting rid of it, its been under your rig for a while?????
spiderman32 is offline
Old March 30th, 2010, 05:15 PM   #5
snodevil
snodevil's Avatar
I was planning to rebuild it and use it. It's just been sitting under the jeep with the tires on it for mock up, but not attached or driven on yet. Only reason I'm not using it now is because I wanted to put in 35spline cromo shafts and it would cost around $200 or so just to rent the boreing tool to bore the spindles to fit the bigger shafts. I ended up coming across a rare 60 HD rear axle from a motorhome that already had the larger dana 70 sized spindles attached on the ends to allow the use of the 35 spline shafts I plan to use. Plus it's 2 " narrower and I wanted to narrow the front 2" as well, so it's was a perfect match for me. Just makes things easier for me that way. So, this ones up for sale!
snodevil is offline
Old April 16th, 2010, 01:11 PM   #6
snodevil
snodevil's Avatar
up
snodevil is offline
Old April 16th, 2010, 01:19 PM   #7
Mr. Beefy
BFT!
Mr. Beefy's Avatar
Add an [img] and [/img] tags around your links
Mr. Beefy is offline
Old April 18th, 2010, 05:17 PM   #8
snodevil
snodevil's Avatar
sold
snodevil is offline
Page generated in 0.22873 seconds with 47 queries
