radious front suspension ?'s - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 2nd, 2010, 03:24 AM   #21
SageJp
SageJp's Avatar
Originally Posted by keithshotrodshop View Post
What kind of coils are you running? Could it be that the coils are from the fullsize and just way too stiff.
I was told that they are Early Bronco springs, but I have the springs out and it still won't flex. I do have stock TJ springs that came with it, but I don't think thats the problem. plus the jeep has a sb chevy, so it isn't much lighter then a E.B.
SageJp is offline   Reply With Quote
Old March 2nd, 2010, 10:56 AM   #22
masterbeatty
masterbeatty's Avatar
i dont think the problem is the spring considering you took them out completly. i would say the arms your limiting factor. id extend them or make a complete new set and i would think that it would fix the problem.
Old March 2nd, 2010, 11:05 AM   #23
kkodet
kkodet's Avatar
I didn't realize you couldn't flex it with the springs removed. That's definitely a problem Something must be binding up.
Old March 2nd, 2010, 11:14 AM   #24
95geo
newbie
95geo's Avatar
Can you change the material isolating the arms from the wedges? That's the part that needs to move and is being restricted. What's in there now? How much room is there between teh arm clamp and the wedge on the axle?
Old March 3rd, 2010, 09:11 PM   #25
SoupCan
SoupCan's Avatar
if the rad arms are too tight around the axle it will restrict articulation bigtime..loosen the arms up a wee bit and test it..u may have to make a thin spacer to slip in there.
Rich
SoupCan is offline   Reply With Quote
Old March 3rd, 2010, 11:05 PM   #26
pipepro
Tack it
pipepro's Avatar
This has been covered really well over on ClassicBroncos. The info given here is mostly correct, the C bushings themselves are what is binding the rotational flex of the axle. Other than switching to a specialty aftermarket arm such as offered by Wild Horses and some other EB fab shops. The only other alternative is to lengthen the radius arm itself, and the longer arm puts more leverage against the C bushing allowing more flex. I am in the middle of this very mod to my Bronco. I dont have real high hopes of making it into a flexy crawler, but I wanted to rid myself of those dreaded drop brackets! Check out this Thread for more Info:
Dan Wheeler\\\\\\\\\\'s Radius Arm Build Thread - ClassicBroncos.com Forums
pipepro is offline   Reply With Quote
Old April 9th, 2010, 01:46 AM   #27
swamper 69
Hopeles Horsepower Addict
With a longer radius arm and proper spring rates and shocks, the radius arm set up will flex with the best of them.
This is right out of the shop, 3600 lb Bronc, o miles, tight everything and still maxed 14" travel shocks on the first flex.
ID:	60768Click image for larger version
Due to resistance in the C bushings this set up does not flex without springs on a jack but needs a bit of force, eg (weight of vehicle). This is not a bad thing as the resistance of the C bushings creates a light sway bar effect similar to the Anti Rock sway bars from Currie and allows good road handling and roll control with light spring rates. A comparable 3 or 4 link on the road is death without an addded sway bar.
I have done this swap on a couple YJ's the radius arm brackets with stock arms are within an inch of the proper Bronco spacing and flex great even with the stock length arms.
You want no more than 180 lb spring rate for the YJ. Deaver super flex coils for the Bronco are 200 LB , some others are a lot more. A TJ/XJ coil works the best and is in the 170 to 180 range.
For an all round trail road rig this is arguably the best set up going (when properly built). Simple, nothing to wear out besides a few cheap bushings, brutally strong, no extra sway bar needed and complete control of axle wrap.
swamper 69 is offline   Reply With Quote
Page generated in 0.23525 seconds with 46 queries
