Chevy D44 shaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 25th, 2010, 03:12 PM   #1
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Default Chevy D44 shaft
Need a Chevy D44 short side inner axle. Don't need a stub but if its attached, no biggie. Also, I think I need an EB long side inner. Gonna narrow a Chev D44 housing to CJ WT and need the axles. Lemme know what you have. Oh, and a set of D30 stubs that take the 760 joints.
Dave
Mulely is offline   Reply With Quote
Old February 25th, 2010, 03:15 PM   #2
PavementPounder
PavementPounder's Avatar
CJ D30 stubs?
What length on the D44 inner?
Old February 25th, 2010, 03:19 PM   #3
Mulely
Mulely's Avatar
Stub shafts, the outters? I thought the D44 short side inners were all the same. I think I need help with this.
Old February 25th, 2010, 03:19 PM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I have the inner and some alloy stubs.
4x4klien (sp?) has a housing for sale and is close to me.
You will have to order the EB shaft from broncograveyard in order for it to be for the 297x/760 joint (all the factory shafts are the smaller 260 joint
Old February 25th, 2010, 03:23 PM   #5
Mulely
Mulely's Avatar
I got the housing already from a buddy. How much you want for the alloys and inner? All I'm missing to do the whole thing is a new set of bearings and the axle shafts. And a pinion yoke. Will using the EB long side be the right one for a CJ WT so I won't have to outboard my springs?
Old February 25th, 2010, 03:26 PM   #6
crazygrady127
crazygrady127's Avatar
You can also try JKOwners.com I seen some on there in the for sale forum pretty cheap !!
crazygrady127 is offline   Reply With Quote
Old February 25th, 2010, 03:58 PM   #7
Jeepaholic
Jeepaholic's Avatar
$150 for the bunch. The diff will be moved more towards the center with that setup but no you will not need to outboard
Old February 25th, 2010, 04:02 PM   #8
crazygrady127
Sorry I didnt notice it was for a Chevy at first. I dont know if the JK axel shafts are the same size and length ??
Old February 25th, 2010, 04:06 PM   #9
Mulely
Mulely's Avatar
That shouldn't be an issue as long as its not a huge amount. The only other option is a Rubi inner right? Or would that put me in the outboarding realm? Would you do $150 shipped to the west side?
Old February 25th, 2010, 04:07 PM   #10
kj kyle
kj kyle's Avatar
http://77cj.littlekeylime.com/Spicer...shortside_.gif
kj kyle is offline   Reply With Quote
Old February 25th, 2010, 04:17 PM   #11
Jeepaholic
Jeepaholic's Avatar
I will check might be able to do that,
Rubi/fsj short side would make it exactly wide track and would still move the diff in slightly (no outboarding). Chevy will make it 59" ish wide
Page generated in 0.27654 seconds with 56 queries
