Camshaft question. single/dual pattern - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2010, 08:21 PM   #1
jeepyj93
Sundowner
jeepyj93's Avatar
Default Camshaft question. single/dual pattern
I have found that certain engines have "single" pattern cams, and some have "dual" pattern cams. What does this mean? Can someone explain this to me please.
jeepyj93 is offline   Reply With Quote
Old February 24th, 2010, 08:45 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
single pattern means that the intake and exhaust profiles have the same exact measurements. a dual pattern will have 2 slightly different measurements between the intake and exhaust lobes. example. single pattern might be 282/282 duration .450/.450 lift.
a dual pattern might be 282/288 duration .450/.467 lift. the exhaust almost always has more lift and duration on a dual pattern cam
Old February 24th, 2010, 08:56 PM   #3
jeepyj93
Sundowner
jeepyj93's Avatar
Thank you for the info. Which camshafts are considered better performance wise? Or does it depend on you engine setup?
Old February 24th, 2010, 09:16 PM   #4
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
there is a lot of technical specs when choosing a cam... rpm operating range, torque converter stall if auto, weight, tire size, intended use of vehicle, compression ratio, etc..
Old February 24th, 2010, 09:44 PM   #5
jeepyj93
Sundowner
jeepyj93's Avatar
I was just wondering cause I am getting an engine out of a cherokee. and certain years have single pattern, and some have dual pattern. I was wondering if one was better than the other. Thanks
Page generated in 0.17351 seconds with 38 queries
