I Need Diesel Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 24th, 2010, 05:24 PM   #1
badazzamc
Get Some
badazzamc's Avatar
Default I Need Diesel Help
I need some info on an older diesel engine. My buddy has an 88 international semi with a Cummins 88NT the only number on the block is 11503584. It needs to have the rockers for the injectors adjusted, the problem is we donít have any specs or info. I have looked around and searched the interweb with no real results. If someone knows more info about this engine or has service information that I could borrow that would be great.
Old February 25th, 2010, 11:48 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
i would set the entire overhead while you're in there
you could call a shop, but they probably won't be too terribly helpful since you aren't paying them
Old February 25th, 2010, 11:49 AM   #3
Nuggets
I fix stuff!
Nuggets's Avatar
Timing pin?
Old February 25th, 2010, 12:50 PM   #4
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Click to View Search Results for 88nt+rocker+adjustment Google: 88nt+rocker+adjustment
Yetti
Page generated in 0.18013 seconds with 36 queries
