which is a better base 302 or 305 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2010, 11:55 PM   #1
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
Default which is a better base 302 or 305
not concidering building either just wondering if anyone has any input
MetalOne21 is offline   Reply With Quote
Old February 21st, 2010, 11:58 PM   #2
Shotgun
I only wheel with boats.
Shotgun's Avatar
302 will be the better motor.
Old February 22nd, 2010, 12:01 AM   #3
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
why?
Old February 22nd, 2010, 12:53 AM   #4
reuben989
reuben989's Avatar
i got one reason its easy to adjust the timing with distributor in front of the motor
reuben989 is offline   Reply With Quote
Old February 22nd, 2010, 04:01 AM   #5
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Originally Posted by MetalOne21 View Post
why?
Ever heard of anyone building a badazz 305????? Of course not they go to the 350. There are plenty of 302's that are well built and used on-road, off-road, and down the track.
Old February 22nd, 2010, 07:25 AM   #6
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
why not the 305 whats the glitch is it that different?
Old February 22nd, 2010, 08:24 AM   #7
NvrTaMe
Jeep Crew
NvrTaMe's Avatar
Send a message via AIM to NvrTaMe
If your not going to build either one. Why ask?
NvrTaMe is offline   Reply With Quote
Old February 22nd, 2010, 08:42 AM   #8
greygoose
I'm the dude
greygoose's Avatar
x2
If I had to pick though I would say 302.
Old February 22nd, 2010, 08:44 AM   #9
masterbeatty
masterbeatty's Avatar
im partial to ford, but ive had a few 302s and have had over 180xxx and never had any major problems.
Old February 22nd, 2010, 08:45 AM   #10
junk90xj
ALLPRO AUTO
junk90xj's Avatar
id pick 302 also because of the amount of parts available and you can buy used stuff from the mustang crowd pretty cheap
http://www.apalansing.com/
Old February 22nd, 2010, 08:54 AM   #11
kj kyle
kj kyle's Avatar
I would run a 305, just because I have built a few small block chevy's so I' familiar with them.
so basically its preference.
kj kyle is offline   Reply With Quote
Old February 22nd, 2010, 09:03 AM   #12
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I'd take the Chevy 302 over the chevy 305, no questions asked.
Old February 22nd, 2010, 09:06 AM   #13
bigdogwaggy
bigdogwaggy's Avatar
from an anti ford guy, i say 302 would be the best bang for the buck if your gonna do a 305 for performance, sell it and to a 350, for a dd reliable go for it.
the biggest reasons for the 302 over the 305 is power per dollar, there is a ton of aftermarket for the 302 not the 305 (there is for the 350 also) a stock 302 vs 305 i would put my money on the 302, the 305 is kinda doggy for performance, (and yes i belive this, and have a 305 powered camaro in the fleet for atestment (that is getting a 350 swap soon enough)) i prefer my 3.8 v6 over the 305.
bottom line bang for buck is in the 302 and 350 not the 305. i mean if your gonna rebuild and the 350-305 are gonna cost the same to build then why not get a bit more pep?
bigdogwaggy is offline   Reply With Quote
Old February 22nd, 2010, 09:14 AM   #14
bigbchevy
missmrgreenagain
bigbchevy's Avatar
302 ho
H.o.r.e
Old February 22nd, 2010, 11:14 AM   #15
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
this is a reply i got from a dragrace fourm
"a ford 302 is a 4.00 bore and 3.00 stroke motor. a chevy 305 is a 3.73 bore and 3.48 stroke motor. short block for short block a ford 302 is a better combo to do 400-500 hp N/A. But I would argue the chevy 305 is a better motor to run if you going to do forced induction. My reasons being: the block is far stronger, there is 5 bolts around each cylinder, the smaller bore actually promotes detonation resistance, the cylinder walls are very thick, easily can be billet capped and splayed"
Old February 22nd, 2010, 11:15 AM   #16
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
seem sound to you guys? or bs?
Old February 22nd, 2010, 11:31 AM   #17
Captain Ledd
Ranger Addiction?
Captain Ledd's Avatar
IIRC the 305 is essentialy a 350 block with a smaller bore? Even still I'm pretty sure it's the same size externally as the 350. So you might as well go with the bigger engine.
The 302 is a smaller package, and this will help with coolng problems in CJ/YJ/etc., if that's what it's going in. It'll still be easier to cool regardless.
The distributor is easier to get to.
Enough aftermarket support to get a wide range of good, useable, power outputs, and plenty of places along the powercurve to put it. (it will like to rev slightly higher than a 305). But with the 302 in my Ranger, it's still got plenty of torque from, more or less, off idle.
To the last reply:
It's 6, 1/2 dozen or the other. The 302 has plenty of Forced air support and forged internals.
Detonation has to do with hot spots in the cylinder and a too high Compression Ratio. Either your clearances aren't correct (incorrect quench) or there a burr maybe somewhere in the combustion chamber. If the CR is too high it will get too hot and unstable from just the force of the piston compressing it, making it far more prone to explode before the spark plug tells it to.
Unless your going nuts with it the 302 will hold up fine to some pretty moderate power outputs, including boost. You would need forged stuff though if you go much past 1-3 psi or so, and it's lifespan would be somewhat shortened even at that.
So I'd look for a clean (hopefully healthy) 302 HO (or 5.0L rather). Roller cam and one of the more powerful factory versions that you can actually find in junkyards.
if your set on a Chevy engine, just go for the 350.
Old February 22nd, 2010, 11:40 AM   #18
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
i actually do have a 5.0...well a few at my desposal... sadly tho their in mustangs, but thanks for the info, when i bought the car i was told it had a 351, got it home and took a closer look at it to find out it was a 302, so i was bummed, but from what i've seen on both fourms seems the 5.0 aint so bad...but still think i prefer my diesel 420...but thanks for the info
Old February 23rd, 2010, 09:11 AM   #19
greygoose
I'm the dude
greygoose's Avatar
302 is a pretty decent motor and has a huge aftermarket, I don't think you'll be disappointed.
Page generated in 0.33483 seconds with 80 queries
