*SOLD* CJ spring over highsteer d30 with rear nt d44 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2010, 10:29 PM   #1
Pokerob
hug life
Pokerob's Avatar
Default *SOLD* CJ spring over highsteer d30 with rear nt d44
$900 CJ spring over suspension with highsteer BOLT IN ready to rock. *all parts have less than 500 miles and I will not seperate
WT D30 front
-1984 cj-7
-373's open (new gears)
-Highsteer D44 waggy knuckles drilled and tapped.
-Highsteer arms
-caliper re-location brackets
-superwinch lockouts
-new rotors/pads
-new ball joints
-stock drag link
-does not include the 1-ton Tie Rod - its gone
-stock shafts w/ new spicer joints
-extra shafts (both sides inners and outters) with old joints
-front sua spring pads are still there and were used to line up the soa pads. cutting them off wont be a problem.
***FREEBIES that can go with the buyer if they want.
-dropped pitman arm (i think its the 3")[/COLOR]
-EDIT: thought i had a stock tie rod that is slightly bent EDIT: i cannot find the bent tie rod but i will keep looking.
NT D44 rear (373's)
-1970's mail jeep
-welded spiders
-new 11" drums and shoes
-new yolk (U-bolt style)
-spider trax Alum Spacers
Dana 30 High steer parts right before install summer 09
Pass side shot
Driver side shot
Driver side shot 2
Trades considered?
-h1's
-h2's
-37 to 39's x 12.5 x 17
Pokerob is offline
Old February 22nd, 2010, 09:44 AM   #2
Pokerob
hug life
Pokerob's Avatar
bizump
Pokerob is offline
Old February 22nd, 2010, 08:21 PM   #3
bigjeep65
Lurker
bigjeep65's Avatar
Are the SUA pads still on the front? What taper are the high steer arms set up for?
bigjeep65 is offline
Old February 22nd, 2010, 10:00 PM   #4
Pokerob
hug life
Pokerob's Avatar
I left them on originally to line up the new spring pads. I never got around to cutting them off but that is easy enough.
Stock tre ends fit, so just stock taper.
Pokerob is offline
Old February 23rd, 2010, 09:51 AM   #5
bigjeep65
Lurker
bigjeep65's Avatar
Thanks. You have a PM
Old February 26th, 2010, 11:39 AM   #6
Pokerob
hug life
Pokerob's Avatar
wanna lift your cj and upgrade to highsteer at the same time bump
*forgot to say that the d30 also has superwinch lockouts as well.
im pulling the axles this saturday.
*freebies i can include if the buyer even wants them
-One 2" or 3" (i think its the 3") Dropped pitman arm (found in my pile of parts).
-I will include all the spring plates I have as well with the u-bolts.
-I will keep looking for a tie rod but at this point its MIA.
Pokerob is offline
Old February 27th, 2010, 03:30 PM   #7
Pokerob
hug life
Pokerob's Avatar
axles are now out of the jeep and
deal pending for saturday 7pm.
Pokerob is offline
Old February 28th, 2010, 10:08 AM   #8
Pokerob
hug life
Pokerob's Avatar
axles are gone.
thanks bigjeep65
Pokerob is offline
Page generated in 0.27461 seconds with 47 queries
