rocker gaurds/ rock sliders - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2010, 02:52 PM   #1
muddyjeep9
muddyjeep9's Avatar
Default rocker gaurds/ rock sliders
i'm planning on making some rocker sliders for my xj since my rockers are pretty much gone.
what i was wondering is what size square tubing should i use?
should i weld it right to my frame/unibody whatever its called or use plates and run four bolts through each place?
and last where should i get the tubing from?
if somebody could let me know that would be dope,
and if some of you guys want to post some pics of your rock sliders so i can get some ideas of what i should do.
thanks,
James.
muddyjeep9 is offline   Reply With Quote
Old February 21st, 2010, 03:03 PM   #2
GREASYHANDS
GREASYHANDS's Avatar
i was thinking of doing the same thing with 2x4 square steel and then makeing some 1.25 tube for sliders off the edges, good luck post ur pics so i can see what it looks like
Old February 21st, 2010, 03:15 PM   #3
muddyjeep9
muddyjeep9's Avatar
soumds like what i'm doing, it will probably be a while before i do this(broken hand) so i really cant weld or anything else ha, but i was going to buy the steel and lay everything out first. i'll take plenty of pics when i do this
Old February 21st, 2010, 03:21 PM   #4
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
I used 3x5 .125 wall square tube, I cut out the entire rocker and pinch weld and went right to the inner rocker.
Old February 21st, 2010, 03:38 PM   #5
muddyjeep9
muddyjeep9's Avatar
inner rocker? my rockers are about a foot long from the front doors so theres about nothing left and i can stick a screw driver through that metal
Old February 21st, 2010, 06:39 PM   #6
pipepro
Tack it
pipepro's Avatar
I did mine with 4x2x.250 square tube.
Rock Sliders - Great Lakes 4x4. The largest offroad forum in the Midwest
I picked up my tube from ALRO, but search around, I think there are better deals to be had.
pipepro is offline   Reply With Quote
Old February 21st, 2010, 09:19 PM   #7
muddyjeep9
muddyjeep9's Avatar
where is alro?
Old February 21st, 2010, 09:39 PM   #8
muddyjeep9
muddyjeep9's Avatar
nevermind i found it on google ha
Page generated in 0.21962 seconds with 48 queries
