phase converter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 21st, 2010, 10:59 AM   #1
Flat_Black
The Dodge Guy
Flat_Black's Avatar
Default phase converter
looking for a 3 phase to single convertor. harbor freight has em for 199 but would like to buy one asap. it will take 2 weeks or so to get it from them.
Old February 21st, 2010, 02:53 PM   #2
Kegger83cj7
Kegger83cj7's Avatar
What size/specs are you looking for? Converting just one motor or multiple? Volts-amps-HP-SF? Let me know I may have some I can get ahold of. I can also get AC drives and motors that may work for you.
Kegger83cj7 is offline   Reply With Quote
Old February 21st, 2010, 03:50 PM   #3
firehawk
Live Action!
firehawk's Avatar
I have seen them on craigslist decently priced.
Old February 21st, 2010, 03:58 PM   #4
Nuggets
I fix stuff!
Nuggets's Avatar
http://shop.ebay.com/?_from=R40&_trk...All-Categories
I have a static phase converter I bought about 5 years ago off ebay that is still going strong. Its a 1-3hp unit that I bought for about 60 bucks including shipping. I also built a 5 hp rotory phase converter out of an old 3 phase motor and a 1/2 hp 110v motor that I use to start it. Super easy to build a rotory phase converter.
Old February 21st, 2010, 05:23 PM   #5
Flat_Black
The Dodge Guy
Flat_Black's Avatar
i have no idea. im looking for one to hook up a 230v 3phase plasma cutter to a single phase 220v. if that helps any
Old February 21st, 2010, 06:04 PM   #6
Kegger83cj7
You should still size the amps correctly for the load. What does the plasma cutter say for the input and output amp draw? If there is no tag left tell me what model/brand/and size plasma cutter and I can look it up for you. Don't quote me on this but I think that some of the new plasma cutters are either single or three phase you just need to change some jumpers where the power cord connects to the machine. There should be a diagram or a connection chart on the inside covers somewhere. let me know if I can help.
Old February 21st, 2010, 06:16 PM   #7
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
Very easy to build. For around $150.00 or less for parts from Grainger. You will need a 3 phase doner motor. with this method all you have to do is flip a switch. But if you want a cheaper method all you will need is a drill, some sort of wheel. and wire. use the drill to get motor turning, turn on power to doner motor. and your converter is up and running. pm me if you want the list for the grainger parts, and schematic of the build.
samurai2240 is offline   Reply With Quote
Old February 21st, 2010, 10:34 PM   #8
Flat_Black
The Dodge Guy
Flat_Black's Avatar
the plasma is a lincoln pro cut 125
Old February 22nd, 2010, 03:05 PM   #9
Kegger83cj7
A pro cut 125 is a 1.25" capacity machine. If this is the machine you have the input amps are fused at 125 amps. The phase converter that would be required to run this at full capacity would be a 40 to 50HP. #1 do you have 125amps of power availible to run this in your shop. #2 A $199 HF may not be big enough for your aplication. I looked them up and the company that supplys them and the manual is unclear on what the HP rating of the $199 one is. This is going to be a good sized converter and I think will not be that cheap. I will have to quote it out and let you know. You can still build your own using a smaller motor to start a larger moter (40-50HP in you case) and it won't cost that much. I will get back to you.......
Old February 22nd, 2010, 04:09 PM   #10
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
he has a 220 single phase Lincoln 180 wire welder hooked up out there and thats the most power he has out there.
Old February 24th, 2010, 09:32 AM   #11
Kegger83cj7
I had my uncle ballpark a price for me and he said 3-$4,000 range for a 40HP unit. I suspect that will be outside of the budjet so get back to me with any questions. I don't have one that big used so sorry I could not be of more help.
Page generated in 0.24871 seconds with 56 queries
