No brake lights ! ,, Help ! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 20th, 2010, 04:14 PM   #1
gigbag
Rust never sleeps !
gigbag's Avatar
Default No brake lights ! ,, Help !
I have a 86 XJ and My brake lights went out the other day ..... I have checked all you bulbs , replaced the brake light switch , and checked all the fuses ... I have running lights but still no brake lights !
What should I check next ? Is there a separate fuse outside of the fusebox for the brake lights ?
I'm done banging my head under the dash today ...
Someone please give me some ideas !
gigbag is offline   Reply With Quote
Old February 20th, 2010, 04:27 PM   #2
NvrTaMe
Jeep Crew
NvrTaMe's Avatar
Send a message via AIM to NvrTaMe
I have the same problem with my 95 YJ
NvrTaMe is offline   Reply With Quote
Old February 20th, 2010, 04:32 PM   #3
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
is the wire that connects to the switch making good contact? Check to see if there is corrosion.
Or is it possible that the indexing of the switch is off... ?
Old February 20th, 2010, 04:39 PM   #4
gigbag
Rust never sleeps !
gigbag's Avatar
I cleaned the contact points on the plug for the switch , and it is a new switch I bought today ..... How do I adjust the indexing of the switch ? I did not see how !
Old February 20th, 2010, 04:49 PM   #5
gigbag
Rust never sleeps !
gigbag's Avatar
And ... with your info , I grabbed the old switch and checked it with a meter "it is still good " ! So I activated the switch and plugged it in ! Still no brake lites ! Doh ....
Old February 20th, 2010, 05:10 PM   #6
redhead_823
redhead_823's Avatar
Do the turn signals work?
redhead_823 is offline   Reply With Quote
Old February 20th, 2010, 05:17 PM   #7
gigbag
Rust never sleeps !
gigbag's Avatar
Turn signals do work !
Old February 20th, 2010, 05:20 PM   #8
redhead_823
Is there power going to the brake switch?
I'm not exactly sure how it works, but I think power goes through the brake switch to the turn signal switch, then to the lights. The turn signals use the same bulb, but probably a different power source.
Old February 20th, 2010, 05:31 PM   #9
gigbag
Rust never sleeps !
gigbag's Avatar
I will check that !
It should be hot wired , no need to have the ignition on ... unlike the turn signals !
I also just noticed that the volt gage it not working ... don't know if that has anything to do with it !
Old February 20th, 2010, 07:35 PM   #10
redhead_823
The voltage gauge shouldn't be on without the ignition, so it probably isn't related.
You're right, the brake lights should work without ignition.
Old February 20th, 2010, 07:39 PM   #11
gigbag
Rust never sleeps !
gigbag's Avatar
engine was on !
Old February 20th, 2010, 08:02 PM   #12
93xjr
Senile Member
93xjr's Avatar
Get your hands on a volt meter or a test light and a friend, or wedge a board on the brake peddle, then test to see if there is power in the bulb socket. If so you may need to check continuity on the ground portion of the socket. Check both of these and post what you come up with.
93xjr is offline   Reply With Quote
Old February 21st, 2010, 12:53 PM   #13
gigbag
Rust never sleeps !
gigbag's Avatar
I was just outside working on it ... what I have discovered is that there is no power to the plug for the brake switch ..... the wires run up into the wiring harness and I'm not sure from there .... I think I am going to figure out which wire is the power wire and which one goes to the brake lights , from there I am going to clip the power wire and run it direct to a hot on the fuse box .... that should do the trick . But let me know if you think there would be a problem with that !
Old February 21st, 2010, 01:39 PM   #14
redhead_823
Sounds good to me. Try giving power to each of the wires that go to the switch, and whichever makes the lights turn on is obviously the one that goes to the lights. Then hook that wire back to the switch, and power to the other side of the switch.
Old February 21st, 2010, 01:58 PM   #15
gigbag
Rust never sleeps !
gigbag's Avatar
Did , Done ..... Success !!!!
Now on to the next project ! Woo Hoo
Page generated in 0.23882 seconds with 68 queries
