want to convert 4.3L to carb - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2010, 10:20 PM   #1
jeepyj93
Sundowner
jeepyj93's Avatar
Default want to convert 4.3L to carb
I have a friend that wants to put a chevy 4.3L v6 in his jeep, but wants to run a carb. Has anyone swapped from a TBI to carb? If so, What all parts do you need to change? I know the intake, distributor, ignition, fuel pump. But I found online that some say you hvae to change the cam too. Does anyone know if that is true? Thank you for any help.
jeepyj93 is offline   Reply With Quote
Old February 19th, 2010, 10:38 PM   #2
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Won't need to change the cam. They put a carbed 4.3 in some of the older mini vans. also you can get a spacer plat to adapt a carb onto the older TBI intakes and then you just need to change the distributor and put a fuel pressure regulator on it.
Old February 20th, 2010, 01:35 PM   #3
jeepyj93
Sundowner
jeepyj93's Avatar
Has anyone converted a 4.3L from TBI to a carb? ANd what distributor did you use?
Old February 20th, 2010, 03:14 PM   #4
RADRICK
RADRICK's Avatar
Find an old 4.3 that was carb. I had an 86 k10 w/4.3 that was carb. I think the early astro vans, caprice,c&k series truck all came with 4.3 as an option in the mid 80's. The dist. looks like a standard HEI, but diffrent pickup & cap.
Old February 20th, 2010, 09:33 PM   #5
ChevyRacer1981
there is a HEI Distributor for the V-6. Then its a 1 wire hook up.
http://www.summitracing.com/parts/PRO-67080/
Old February 20th, 2010, 11:47 PM   #6
jeepyj93
Sundowner
jeepyj93's Avatar
So would you be able to get a distributor for a carbed 4.3L, and use it on a newer engine with an aftermarket ignition control box?
Old February 21st, 2010, 01:02 AM   #7
unclebeaner
can you hear the banjos?
unclebeaner's Avatar
yes msd makes a few distributors for these. conversion intake and dis. and your rollin
Old February 21st, 2010, 09:52 AM   #8
jeepyj93
Sundowner
jeepyj93's Avatar
So can i use a stock distributor from a carbed 4.3L and wire it to an aftermarket ignition box? Or do I need to buy an aftermarket distributor?
Old February 21st, 2010, 09:22 PM   #9
kkodet
kkodet's Avatar
I've done this before when I put a 4.3 in my Samurai.
You don't have to change the cam in the TBI motors. The later distributorless engines do not have a cam gear.
The only year for the quadrajet carb on the 4.3 astro is 1985. That intake is very tall, and is basically a factory tunnel ram.
Fullsize cars and trucks used a 4 barrel in 85 and 86.
The HEI distributor from those vehicles is the computerized large cap. It will not work without some mods.
Basically, you need to pull the guts out of the 4.3 distributor and replace the ignition module from a 70's HEI V8. You retain the six point pickup, but eliminate the computer function. This is what I did with my 85 astro distrubutor and it worked fine.
You can also find a 81-86 Chevy 3.8 90 degree V6 (distributor in the back) HEI distributor from a G-body car. You will need to do the same module swap unless you find a Canadian car, in which they ran the old one wire style. If you happen to find a canadian 3.8 V6 in a junkyard, pull the exhaust manifolds as well, as they are non-emission block hugger style that will bolt to a 4.3 but take up much less room than all the factory 4.3 manifolds. They are getting very hard to find and somewhat valuable.
Also, you will need to run an electric fuel pump, as the TBI motor does not have the provision for a mechanical fuel pump.
Old February 21st, 2010, 09:31 PM   #10
forbyefore
forbyefore's Avatar
I am not sure if this helps you at all but the 4.3 came equipped with a carb in some marine applications. You may be able to scavenge some parts from one.
forbyefore is offline   Reply With Quote
Page generated in 0.24281 seconds with 53 queries
