89 ford f150 running problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2010, 09:02 PM   #1
prostock2414
Default 89 ford f150 running problems
i have a 89 for f150 with a 351w and it will run fine at idel but if you hold it at a set rpm like 2500 to 3000 for 2-3 mins it will bogg out till it dies ive changes the spark plugs new fuel filter and i still cant figure it out filled the tank so have any advice thanks
prostock2414 is offline   Reply With Quote
Old February 20th, 2010, 12:22 AM   #2
prostock2414
bump
Old February 20th, 2010, 12:49 AM   #3
MiNi Beast
MiNi Beast's Avatar
have you checked the pump? sounds like a bad fuel pump to me.
Old February 20th, 2010, 09:06 AM   #4
Yota Bill
is that free revving or under load? I would check fuel pressure/volume and look into secondary ignition...also make sure there are no vacuum leaks, pay close attention around the intake gasket
Old February 20th, 2010, 03:16 PM   #5
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
agreed, if you have a multimeter you should just be able to check the continutity (ohms) and that'll tell you if your pump's fried
MetalOne21 is offline   Reply With Quote
Old February 20th, 2010, 03:51 PM   #6
Yota Bill
that will tell if the pump motor is ok, but not the rest of the pump...best bet is to check flow rate and pressure
Old February 20th, 2010, 04:01 PM   #7
MetalOne21
BS WRECKING CO.
MetalOne21's Avatar
yea...do f150s have the place on the fuel rail where you can hook a gauge up?
Old February 20th, 2010, 05:38 PM   #8
bigarsetrucks
Barkeep I need a DRINK
bigarsetrucks's Avatar
Yes they do
bigarsetrucks is offline   Reply With Quote
Page generated in 0.29063 seconds with 47 queries
