sb 350 starter help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2010, 08:35 PM   #1
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Default sb 350 starter help
Ok so I need to know how this starter wires up. It has one big post for the battery lead and then has 2 small posts. How do I figure out which post the small wire goes to? And should there be a ground wire to the starter? Thanks again.
lastmanstandin is offline   Reply With Quote
Old February 19th, 2010, 08:44 PM   #2
sanman
sanman's Avatar
the small one goes on the post marked with an S
sanman is offline   Reply With Quote
Old February 19th, 2010, 08:57 PM   #3
lastmanstandin
EvL 1
Ok thanks I'll take a look at it and see if I can find the S.
Is there supose to be a ground cable on it?
Old February 19th, 2010, 08:59 PM   #4
mboies
BS MUDDERZ
mboies's Avatar
nope it will ground threw the block
mboies is offline   Reply With Quote
Old February 19th, 2010, 09:12 PM   #5
sanman
sanman's Avatar
if i remember right there should also be a wire from your alternator to the big post on the starter i'll double check or i'm sure some one will correct me if i'm wrong
Old February 19th, 2010, 09:13 PM   #6
lastmanstandin
EvL 1
Ok well this is in me 94 yj if that makes a difference.
Old February 19th, 2010, 09:14 PM   #7
mboies
BS MUDDERZ
mboies's Avatar
if i remeber this one has it run through the distribution center under the hood
Old February 19th, 2010, 09:30 PM   #8
Tomahawk715
Tomahawk715's Avatar
It does ground thru the block--but if you want to aid in cranking however you can run a ground wire from starter bolt back to the battery--use proper size. Starter is one of the largest electrical draws when engaged and can use all the help it can get. Plus its a second ground for the motor.
Tomahawk715 is offline   Reply With Quote
Old February 19th, 2010, 09:39 PM   #9
lastmanstandin
EvL 1
Ok I think I'll do that, it sure won't hurt anything. Thanks.
Page generated in 0.30254 seconds with 50 queries
