Wheel Size - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2010, 08:00 PM   #1
LuckyCharm4x4
LuckyCharm4x4's Avatar
Send a message via AIM to LuckyCharm4x4 Send a message via Skype™ to LuckyCharm4x4
Arrow Wheel Size
I am looking at getting some new rims to put some beadlocks on. I am wondering if I should get larger rims (16 or 17's), or if I'd be alright with 15". I do plan on upgrading my axles and brakes some day, so I am keeping that thought in the back of my mind (for clearance sake). That is why I am thinking I may need 16's or so. Also if I move up to 37-39's some day will it be better to run the larger rims, or again, will I be ok with 15"?
Thanks in advance.
~Bry
LuckyCharm4x4 is offline   Reply With Quote
Old February 19th, 2010, 08:04 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
If 15" wheels will fit over the brakes on your axles, I would stick to them. It is much easier to find good used tires for 15" than any other size. Not only that there are way more styles and sizes available for 15" wheels since they have been around for decades. An added bonus is tires for 15" wheels are also a little cheaper the larger wheels.
Old February 19th, 2010, 08:34 PM   #3
somer1
You Get the Big One
somer1's Avatar
17's that way they clear the brakes, give more room between wheel and hubs for easy'er cleaning, tire prices are alittle more but they are becoming much more common. Plus 17's clear most highsteer arms without to much trouble.
somer1 is offline   Reply With Quote
Page generated in 0.19507 seconds with 32 queries
