700r4 issues - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 19th, 2010, 10:43 AM   #1
jeepfreak81
81 inches of fun
jeepfreak81's Avatar
Default 700r4 issues
50k mile trans, sat for 4 years in the truck.
I have been driving it again and everything was fine, until recently. It wants to stick in 3rd, and reverse will not fully engage. I thought I lost the gears, but after parking it on a hill for a week everything was functional again with no slippage.
Parked it for a bit, came back and reverse and 4th were not engaging again.
What could I be looking at? Just trying to decide what shop to take it to, but want to be prepared with the cash in hand.
Old February 19th, 2010, 10:51 AM   #2
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Are you gonna pull it yourself?? If you wanna drive north my friends dad does tranny for fairly cheap! He's in the auto trader as well
Old February 19th, 2010, 10:52 AM   #3
jeepfreak81
81 inches of fun
I'm not crawling under it in this cold, and I will be needing it sooner then I can get to it with my work schedule right now.
Old February 19th, 2010, 10:55 AM   #4
Hoss Blazer
!SPARTY ON!
Good luck! It's gonna cost a pretty penny taking it to a shop i bet
Old February 19th, 2010, 10:58 AM   #5
PCK_4xCustoms
r00t4r3d
PCK_4xCustoms's Avatar
Send a message via AIM to PCK_4xCustoms
id start with dropping the pan. drain the fluid and put a new filter on it then refill with fresh ATF
that may do it.
otherwise it could be $500+ for the shop to do it
PCK_4xCustoms is offline   Reply With Quote
Old February 19th, 2010, 10:59 AM   #6
jeepfreak81
81 inches of fun
that may do it.
The first time was about $800, if it goes to the shop I have other stuff for them to look at anyway I have to have the truck reliable, so right now cost isn't the biggest issue.
Keep my local mechanic busy if nothing else
Old February 19th, 2010, 11:05 AM   #7
Tom
Because racecar
Tom's Avatar
Silly question, But did you check the fluid level?
Old February 19th, 2010, 11:06 AM   #8
jeepfreak81
81 inches of fun
Valid question
Yes I did, and that is why it was weird because it was acting like a low fluid issue. I was thinking maybe the valvebody might have something sticking?
Old February 19th, 2010, 11:11 AM   #9
Tom
Because racecar
Tom's Avatar
Originally Posted by jeepfreak81 View Post
Valid question
it most likely does..... I'm thinking boost valve. Is this the one that Bill did and you had to have the case swapped due to cracked case from a drive shaft?
Old February 19th, 2010, 11:13 AM   #10
jeepfreak81
81 inches of fun
No I still have not done anything with that, too much stuff came up between my wedding last year and some surgeries I have had to have.
I should be getting that trans done in the next month or two. This is the trans in my 1992 Suburban.
Page generated in 0.20601 seconds with 53 queries
