AMC 304/TF727 combo? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 18th, 2010, 02:01 PM   #1
orionn
orionn's Avatar
Default AMC 304/TF727 combo?
Has anyone here put an TF727 behind an AMC 304 V8?
If so, what stall torque converter did you use (its a lockup converter trans).
I know these came behind the AMC 360 V8's, but why not the 304?
Is it just becouse AMC felt the 727 was too heavy duty for a CJ so it just went into the heavier Wagoneers?
Anyone know why I should not do this? (727/304 combo)
Thanks
orionn is offline   Reply With Quote
Old February 18th, 2010, 11:17 PM   #2
orionn
orionn's Avatar
Anyone have input?
I am prepairing to do this in the next few weeks to get my '71 Jeepster Commando back up and running. (it caught fire just befor last Thanksgiving ) and I need to order a lockup Torque converter.
Old February 19th, 2010, 09:34 AM   #3
PavementPounder
PavementPounder's Avatar
Your flexplate is dual-patterned, correct? The 86ish-down OEM style flexplates were. Cheapo aftermarket jobs and the later OEM units are not.
Old February 19th, 2010, 06:16 PM   #4
amundaza
Terminator 2
amundaza's Avatar
Isn't your 71 a passenger side drop? What transfer case are you planning on running with the 727?
If it's a Dana 300, then you're going to run into the issue of the front drive shaft being really close to the buldge in the passenger side of the 727 case/pan.
What tranny & t-case are/were in the 71?
amundaza is offline   Reply With Quote
Old February 20th, 2010, 03:39 PM   #5
orionn
orionn's Avatar
Yes mine is an OEM dual pattern flexplate.
Yes, passenger side drop frt axle. Its a stock D27
It currently has a t150/D20 trans/t-case combo in it. Only the D20 was stock,
They came with TH400/D20 combos factory. I could use a TH400, but they really suck up the HP just to make them run, and I was hoping to make it a little more highway friendly using the lockup torque converter.
I had read that there can be clearence issues using the 727 on a passenger drop axle, but the reality is, this wont be driven offroad, so I probably wont even put the driveshaft back on and just leave it 2wd. but the option would be there if someone were to decide to do that.
I have a purpose built '71 commando for wheeling, and this '71 is for driving.
thanks
Old February 22nd, 2010, 09:27 PM   #6
amundaza
Terminator 2
amundaza's Avatar
I looked at a TF727/D300 combo yesterday in a CJ7 ... the driveshaft is about 1" below the buldge in the tranny pan, going the PSD front axle. He's had a few issues where it has rubbed under spring compression.
If you're going go 2WD on the 71, why mess with a t-case? Why not just run a RWD tranny?
Old February 23rd, 2010, 10:39 AM   #7
orionn
orionn's Avatar
I already have an NOS Tf727 4x4 trans, using it gives me the option to drop a driveshaft in for the dunes or (very) light trails.
What type of driveshaft was he using? I was going to use the stock solid bar driveshaft, its only about 1" in diameter, I figure it would clear except under extream compression, and I can put in a bump stop to linit that.
Do you know what torque converter he was using? was it a lock converter?
thanks for the input
Old February 23rd, 2010, 02:25 PM   #8
amundaza
Terminator 2
amundaza's Avatar
He was using the smaller diameter CJ front shaft (not a double cardan, like the Waggy's use). He had a higher stall converter, so I'm guessing its a non-lockup 727 he has. FWIW, the lock-up 727 is good for about 1.5 MPGs over the non-LU unit.
Also, he did run the Jeep at Silverlake with this setup, as well as mudding with it over here in the Lapeer/Davison area.
Old February 23rd, 2010, 08:42 PM   #9
orionn
orionn's Avatar
Sounds like it was a decent setup then?
Thanks for the input, I'll post up how it turns out
Old February 23rd, 2010, 08:47 PM   #10
amundaza
Terminator 2
amundaza's Avatar
It looked sweet to me ... the whole CJ was nice. You're welcome ... hope it works out well for you.
Old February 23rd, 2010, 08:52 PM   #11
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I run the 727 behind my mopar 360 and when I first did the engine swap I put the engine in Center between the frame rails. Fast forward a season and I go put the front d-shaft in....it hit the pan. So I had to move the engine over to the passenger side about 3" to clear. The d-shaft I'm using though is heavy DOM connected to an agricultural joint so that could be one main reason it hit. I've heard of people notching the pan to overcome this as well.
Page generated in 0.37533 seconds with 56 queries
