High Voltage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 16th, 2010, 10:29 PM   #1
SBC YJ
Heavy Chevy
SBC YJ's Avatar
Default High Voltage
Noticed earlier...the volt gauge was running 15-16 a tad bit high. On the way home i looked down and it was running almost 19V. What the hell would do that???? My experiences in the past only made the voltage drop.
04 GMC 2500 HD 6.6L Duramax
Anyone got any ideas???
SBC YJ is offline   Reply With Quote
Old February 16th, 2010, 10:31 PM   #2
Nuggets
I fix stuff!
Nuggets's Avatar
Change your alternator.
Old February 16th, 2010, 10:37 PM   #3
SBC YJ
Heavy Chevy
SBC YJ's Avatar
Yeah...thought maybe it was something else. Never had one fail and run higher juice
Old February 16th, 2010, 10:41 PM   #4
koochman450r
koochman450r's Avatar
your alternator has an internal voltage regulator. They can fail in either way low or high. Replace your alternator.
koochman450r is online now   Reply With Quote
Old February 16th, 2010, 10:41 PM   #5
SBC YJ
Heavy Chevy
SBC YJ's Avatar
Wow just looked at how much an alternator is...375.00
Old February 16th, 2010, 10:42 PM   #6
SBC YJ
Heavy Chevy
SBC YJ's Avatar
thanks didn't know that...i'll get it checked tomorrow to make sure
Old February 18th, 2010, 08:06 PM   #7
SBC YJ
Heavy Chevy
SBC YJ's Avatar
It wasn't the alternator...i have two batteries. The main batt. shorted out causing all hell to break loose. Two new batteries...now back in business
Old February 18th, 2010, 08:21 PM   #8
boggin-machine
boggin-machine's Avatar
never seen a battery actualy cause it to throw more power then it should like that. if your truck was running 16 volts our truck should have burned up some bulbs. is the guage just taking a shit? thats alot of power.
Old February 18th, 2010, 08:43 PM   #9
SBC YJ
Heavy Chevy
SBC YJ's Avatar
No...works now and is reading 14 with new batts. The batt shop i went to said since everything is computer controlled it's possible that it just made everything go haywire having the shorted batt.
Old February 21st, 2010, 01:20 PM   #10
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Having a bad battery can cause a load and make the alt go full field and try to charge it up. Its actually not uncommon. The first thing to check with any starting/charging problem is always the battery.
BAD93SBLZR is offline   Reply With Quote
Page generated in 0.27751 seconds with 53 queries
