Eliminate Dana 30 Vac Disconnect - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 23rd, 2006, 09:46 PM   #1
Chop
Mischievous Badger
Chop's Avatar
Default Eliminate Dana 30 Vac Disconnect
i have a vac disco D30 and i want to know if i can put a tj pass side long shaft. inplace of that fag ass vac disco 2 axle shaft style. im just looking to keep it going so i can wheel till winter
Old July 23rd, 2006, 10:53 PM   #2
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Yes you can.
You will need to add a seal to the passenger side of the D30, however.
I did this years ago by modifying the housing to accept a driver's side seal, but I know there is a part number that will work without modifications.
Old July 23rd, 2006, 11:40 PM   #3
Chop
Mischievous Badger
Chop's Avatar
Originally Posted by Cooter
Yes you can.
rock on. yeah i dont want to put any more work than i have to in this front axle. where do i install the seal behind the carrier bearing like a tj or at the end my the vac disco?
Old July 24th, 2006, 12:58 AM   #4
Cooter
Cooter's Avatar
Just like a TJ.
Here is a writeup for one of our Club members who did the swap in a YJ
Old July 27th, 2006, 10:03 AM   #5
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Lol... you just want credit cooter I have a part # for a seal that will work without grinding the housing. But the grinding is the better way for it is a better seal.
Old July 27th, 2006, 03:15 PM   #6
Cooter
Cooter's Avatar
LOL, I didn't think so, but they do have a saying at GLJT- "It's all about the Cooter" :tonka:
Old July 27th, 2006, 04:50 PM   #7
KILLER"B"468
Yankabilly
Old August 3rd, 2006, 06:26 PM   #8
Chop
Mischievous Badger
Chop's Avatar
what is the part number for the seal with out grinding. i found a axle shaft out of a tj and i was hoping that a TJ seal would work?
Old August 4th, 2006, 01:34 PM   #9
Chop
Mischievous Badger
Chop's Avatar
so far i have got the part number of the seal which is a national seal pt#40576s (thank you killer B) im just waiting untill tomarrow morning for it to come in. and i have a passenger side axle shaft out of a 98ish TJ.
here are some pics
old axles:
drivers side seal stays the same
Add and passenger side seal if you want to grind the housing and put the correct seal in the PT# you need is a timkin 710068 or the same and a TJ axle shaft seal
if you dont want to grind the housing like me you can use this part# national seal PT#40576s harder to find these seals came in older jeeps with axles like the dana 27 and a few others. but you will not need to grind the housing
if you go this route i stacked 2 seals together to make a better seal. but i did need to grind the outer seal metal surface to make it easyier to fit in the housing.
here is the vac disco housing. i would take the old bearing out of here to make a little more room for the new shaft. as for the seal im going to leave that because i really dont care.
more pics to come when i get the seal
Old August 5th, 2006, 11:33 PM   #10
Mclovin
"The Situation"
Mclovin's Avatar
Well did you get it done for tomarow ??
Old August 6th, 2006, 01:56 AM   #11
Chop
Mischievous Badger
Chop's Avatar
yup its done i will be at the mounds around 12 - 1 oclock with BigBlue2230 ridin shotgun
Old August 6th, 2006, 10:08 AM   #12
Sandals
Fucking Zen as Shit
Sandals's Avatar
See now....
what you should've done...... Welded the spider gears together up front, instant spool.
Convert the Vacuum disco to a manual and wala... instant ARB
Old August 6th, 2006, 06:34 PM   #13
Chop
Mischievous Badger
Chop's Avatar
Originally Posted by Sandals
See now....
it was a manual untill all of the bearings in that area dident want to stay in there spot anymore.:tonka:
Page generated in 0.37310 seconds with 62 queries
