1995 chevy diesel check engine light codes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 15th, 2010, 11:08 AM   #1
don4life
don4life's Avatar
Default 1995 chevy diesel check engine light codes
I have a 95 suburban 6.5L diesel and im getting two check engine light codes
36
Injection Pulse Width Error (Response Time Long)
78
Wastegate Solenoid Fault
wanted to see if anyone has encountered these and what i need to fix???
don4life is offline   Reply With Quote
Old February 15th, 2010, 08:37 PM   #2
don4life
don4life's Avatar
ok got 78 taken care of but anyone know about 36
Old February 15th, 2010, 08:52 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
my guess is you have a clogged injector that is taking too long to spray correctly. pull the injectors out and see if they are dirty. couldn't hurt to do anyways.
Old February 15th, 2010, 09:09 PM   #4
Tom
Because racecar
Tom's Avatar
It sounds like A PMD is going south (Pump mounted Fuel Driver) which is located on the injection pump. The PMD controls the pulse width but another common cause of DTC36 is a sticking fuel solenoid in the IP.
Tom is online now   Reply With Quote
Old February 21st, 2010, 01:40 PM   #5
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
A bad PMD can cause lot of issuses. Its very common on the 6.5 diesels. Does it stall out or do anything else funny. The good news is a PMD is not that much money, the bad news is its kind of a pain in the ass the to change. You also want to make sure all the grounds are good.
BAD93SBLZR is offline   Reply With Quote
Old February 21st, 2010, 01:58 PM   #6
don4life
don4life's Avatar
doesn't stall or anything runs a little rough when cold but that's about it beside the fact that the wastegate actuator isn't working.
Page generated in 0.21880 seconds with 41 queries
