Broken Drill-bit, how to drill out? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 15th, 2010, 10:40 AM   #1
amc78cj7
amc78cj7's Avatar
Default Broken Drill-bit, how to drill out?
Drilling a pilot hole in a grade 5 3/8" bolt in our bronco frame when suddenly the 5/32 pilot bit snaps inside the bolt. What to do now? It was a cobalt bit. Can't seem to drill through it with another bit and there is no visible fluting to get a bit extracter in. The bit broke with nothing hanging out either...
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old February 15th, 2010, 10:41 AM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Torch.
Old February 15th, 2010, 10:42 AM   #3
beejers
always building
beejers's Avatar
small burr.
beejers is offline   Reply With Quote
Old February 15th, 2010, 10:45 AM   #4
bigbchevy
missmrgreenagain
bigbchevy's Avatar
sol ........fire stick
H.o.r.e
Old February 15th, 2010, 10:48 AM   #5
clean79dirty03
carbide bur. or carbide drill. Half to find something harder the the cobalt drill. But be careful carbides brittle.
clean79dirty03 is offline   Reply With Quote
Old February 15th, 2010, 10:50 AM   #6
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Weld a nut to the bolt, use socket to extract.
Old February 15th, 2010, 10:52 AM   #7
joe_jeep
welfare wheeler
joe_jeep's Avatar
drilling through a cobalt bit will be very tough. got access to a plasma cutter or cutting torch. just burn through it. then re-tap the hole to bigger size or weld a nut on the hole.
perhaps go all the way around the broken bolt and bit with a good hole saw. plate over the hole then re-drill and tap.
just a few thoughts. good luck
Old February 15th, 2010, 10:53 AM   #8
rubicon
Try a left handed drill bit sometimes it will back out
rubicon is offline   Reply With Quote
Old February 15th, 2010, 11:08 AM   #9
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
Works really well, if you can get to it with welder.
samurai2240 is offline   Reply With Quote
Old February 15th, 2010, 02:45 PM   #10
amc78cj7
amc78cj7's Avatar
The remaining bolt shaft is behind the surface of the frame so no access to weld a nut. Plus the bolt is seized so not sure that would do a whole lot of good. The original bolt head snapped off.
Will see if I can find a carbide tip. If not I may have to buy a $300 oxy-ace torch
Old February 15th, 2010, 03:02 PM   #11
firehawk
Live Action!
firehawk's Avatar
Take a punch and break it up into pieces and dig them out.
I have had to do this too many times but luckily it has been a while since.
Old February 15th, 2010, 04:21 PM   #12
amc78cj7
amc78cj7's Avatar
A punch is going to break up a cobalt bit? I suppose if the punch were harder than the cobalt.
Old February 15th, 2010, 04:25 PM   #13
HVYRTFT
Reed my teef
HVYRTFT's Avatar
it could be, they're designed to be struck, so they need to be harder than what they are striking, so they do not deform, or shatter.
Old February 16th, 2010, 03:30 PM   #14
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
at my buddies machine shop I have seen him use small endmills on die grinders to eat out busted drills or taps.
Old February 16th, 2010, 03:33 PM   #15
jon_xj90
fake it till you make it.
jon_xj90's Avatar
i've done this several times, .250 carbide end mill chicked in a die grinder will chew at it, SAFETY GLASSES! i don't have much more than that as normally any broken drill bits i've done have been on a machine, not on the vehicle.
jon_xj90 is offline   Reply With Quote
Old February 16th, 2010, 05:23 PM   #16
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
A "B F H" and a center punch works.
Old February 22nd, 2010, 09:38 PM   #17
amc78cj7
amc78cj7's Avatar
Wanted to follow-up with the solution. The punch did not work. Any new cobalt bit just got dull as it rubbed against the stuck bit. No local stores had carbide bits in stock.
In the end I took a die grinder to it. Now the hole is a bit bigger than the original 5/16 hole (it's a 3/8 bolt); so I ordered a weldnut from mcmaster carr and will try to make that flush with the frame with a combination of mig welding and jb-weld.
Old February 22nd, 2010, 09:44 PM   #18
curbdog17
Mini Van
curbdog17's Avatar
If you have a welder or use of one Just weld it dont mess with the JB-weld.
Page generated in 0.35079 seconds with 77 queries
