02 F-150 Diff help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2010, 03:17 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default 02 F-150 Diff help
I believe I need to replace my rear carrier bearings, and possibly the pinion bearing. If I am just replacing the bearings, is it necessary to measure the backlash, pinion depth,preload, and check the gear contact pattern? Or can I simply install the new bearings with the same shims that came out? This is on an 02 F-150 4x4 4.6L, with an 8.8.
Old February 14th, 2010, 05:12 PM   #2
Bishop
Bishop's Avatar
i would re-do it all if it was mine.
maybe install it with the old shims and see if it measures out.
but as far as if it is required or not, im not sure.
Old February 15th, 2010, 08:19 AM   #3
fsumotorhead
N8KVB
fsumotorhead's Avatar
x2
but i do not believe '02 F-150s had the 8.8, i would double check just to be sure before ordering parts.
Old February 15th, 2010, 05:41 PM   #4
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Originally Posted by fsumotorhead View Post
x2
If I were you, I would double check my Ford knowlege before posting about shit you clearly know nothing about.
Old February 16th, 2010, 07:24 PM   #5
fsumotorhead
N8KVB
Page generated in 0.22248 seconds with 38 queries
