Hood release - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2010, 10:47 AM   #1
rob4407
rob4407's Avatar
Default Hood release
I have a cherokee and whenever I pop the hood, only the driver side releases, and will not latch back down. I want to manually release the whole hood, is there a way to do it without trashing the entire hood?
rob4407 is offline   Reply With Quote
Old February 14th, 2010, 11:03 AM   #2
xj4life
xj4life's Avatar
if you're having problems getting the hood to open pull the head light assemblies and you can unbolt the catches from the body. once you've got everything open just get all the moving pieces lubricated well and moving freely and you shouldnt have any more problems
Old February 14th, 2010, 12:00 PM   #3
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
lube lube and more lube. also on every xj I have owned I have drilled out the crappy rivets on the hood pivot and replaced them with machine screws and loc-tite.
Page generated in 0.29067 seconds with 32 queries
