My Detriot locker ? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2010, 10:40 AM   #1
ScottK
99tjWhore
ScottK's Avatar
Default My Detriot locker ?
I have a 99 tj just bought..
d44 w/4.56 rear
Now I have only power to the drivers side tire ?
Will a locker go bad with out telling you ?
It was my understanding that if it goes the hole ass goes w/it
I bound up the drives side tire and it still spun w/the passenger
side limp/no power
No sounds that say its hurting
PS. i found some fluid on the inside wheel well. brake fluid is fine.
Is it possible that was from my axle shaft ? (passenger side)
Or the coffee can of diesel berried in the snow ? lol
any help would be great..
thank you
ScottK is offline   Reply With Quote
Old February 14th, 2010, 01:52 PM   #2
smasheromalley
smasheromalley's Avatar
Sounds broken or improperly installed. Whatever is wrong should be pretty easily visible by just taking off the diff cover. Are you sure it has a detroit locker?
Old February 14th, 2010, 02:32 PM   #3
oscartj
oscartj's Avatar
Passenger side axle shaft broke?
oscartj is offline   Reply With Quote
Old February 14th, 2010, 02:42 PM   #4
smasheromalley
D44 should be a C-clip axle i think?
Old February 14th, 2010, 02:44 PM   #5
oscartj
oscartj's Avatar
Really? I thought just the D35 was C-clip.
Old February 14th, 2010, 04:58 PM   #6
shawn
Resident HVAC/R Jambi
shawn's Avatar
U just bought the jeep, are you sure there is a Detroit in there? Doesn't sound like it.
Old February 14th, 2010, 05:08 PM   #7
ScottK
99tjWhore
ScottK's Avatar
I know i have a d locker
I could feel it when i bought it..
COULD
If the axle shaft broke? I would heir that ? bangin around ?
I need to look up C-clip ? lol
So a failure in my locker doesn't mean a failure in my rear drive ?
I still have full power to my drive side wheel
And thanks for the impute
Old February 14th, 2010, 05:18 PM   #8
shawn
shawn's Avatar
I don't know how you can improperly install a Detroit Locker. I ran Detroits front and rear. Never did I ever have just one wheel spinning unless I had a broken shaft.
And, a D44 should not be C-clip, not any D44 I've had apart.
Old February 14th, 2010, 05:20 PM   #9
shawn
shawn's Avatar
If you are positive you have a Detroit, then jack up the rear end, and spin that tire. With the Jeep in neutral both tires should spin the SAME DIRECTION.
Old February 14th, 2010, 05:22 PM   #10
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Just take the diff cover off and look
lastmanstandin is offline   Reply With Quote
Old February 14th, 2010, 05:22 PM   #11
kj kyle
kj kyle's Avatar
is it a detroit "true trac?"
kj kyle is offline   Reply With Quote
Old February 14th, 2010, 05:44 PM   #12
ScottK
99tjWhore
ScottK's Avatar
Thumbs up
powertrac no slip d 30 in front and it works great, I will jack it up and give it a spin.
I am sure i have NO power to the pass side rear.
D locker
Alloy USA Chromalloy rear axle shafts installed
D44 And 4.56 gears..`
the locker was always engaged but i will message the po
And thank you again//
I will have it up tomorrow..
And answer
Old February 14th, 2010, 08:20 PM   #13
Dylan
Dylan's Avatar
dana 44 is NOT a c-clip axle. If you have power to only one wheel, there is a good possibility of a broken axle shaft. No you will not notice it on a non c-clip axle. There may have been a bang but maybe not. Put the jeep in gear and jack up the passenger side. if it turns and you don't hear clicking noises its probably a broken shaft. Take the breaks off that side and pull the 4 bolts that holds the shaft in and pull the shaft to examine it.
For those that said it will be obvious when you pull the cover, thats not so true with a detroit in a 44. Its a completely incased carrier and you wont be able to see inside of it.
Old February 14th, 2010, 08:26 PM   #14
smasheromalley
Old February 14th, 2010, 09:12 PM   #15
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
I love all the misinformation being spread around lately, no it is not c clip.
Old February 15th, 2010, 06:11 AM   #16
ScottK
99tjWhore
ScottK's Avatar
aww hell then.. now i need to get my hands on a new Alloy USA Chromalloy rear axle.. I was lookint to find out if it is a 30 pline ? now i will know
ill let you guys know what i find..
pulling it today..
thank you
Old February 15th, 2010, 07:40 AM   #17
smasheromalley
Thanks guy, pretty well established by now. Way to save the day
Old February 15th, 2010, 04:02 PM   #18
ScottK
99tjWhore
ScottK's Avatar
every one kiss and play nice, I didn't get my jack under the jeep today.
but all the axles i have looked at for the d44 w/4.56 gears are 30 spline..
Am i rite that a D44 = 30 spline axle ? with 4.56 gears..
I am looking for the pass side rear alloy usa replacement axle to go into my d44 4.56 w/Detroit locker
I googled it and alloy / jegs are not answering my call ..lol ..
any ideas..
Old February 15th, 2010, 04:38 PM   #19
shawn
shawn's Avatar
lets light this up again..
And thank you
Yes, a D44 is 30 spline, no matter what gear ratio.
Old February 15th, 2010, 04:42 PM   #20
ScottK
99tjWhore
ScottK's Avatar
Thumbs up great help every one
thank you Shawn you have been a great help..
I owe you a when we meet on the trail..
Page generated in 0.56313 seconds with 83 queries
