no heat - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 14th, 2010, 10:37 AM   #1
Timmy
Timmy's Avatar
Default no heat
I have an 03 Blazer and no I have no heat. I have replaces the thermostat and have check the coolant level. I have no leaks anywhere. Any suggestions.
Timmy is offline   Reply With Quote
Old February 14th, 2010, 10:38 AM   #2
Ridin Dirty
kixx007 wants to be me
Ridin Dirty's Avatar
What temp is it running at? Blend door may not be working?
Old February 14th, 2010, 10:44 AM   #3
Timmy
Timmy's Avatar
The temp is running at about 200. That's the only other thing I could think of. Would that be just replacing the temp control switch.
Old February 14th, 2010, 10:45 AM   #4
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
Heater core. I recently did mine , it is a big problem with s-series vehicles.
If you decide to tackle the heater core let me know. I can send you a really good write up on how to do it !
JohnL is offline   Reply With Quote
Old February 14th, 2010, 10:55 AM   #5
Timmy
Timmy's Avatar
If it was the hearter core, wouldn't it be leaking somewhere?
Old February 14th, 2010, 10:56 AM   #6
JohnL
Go until it breaks.
JohnL's Avatar
Mine had got plugged with nasty old dex-cool and it never leaked but I had no heat. After I replaced the heater core it was great again and the old heater core weighed a lot more than the new one from build up on the inside.
Old February 14th, 2010, 10:57 AM   #7
blownexploder94
Todd
blownexploder94's Avatar
yes alot of the s-series plug the heater cores up pretty bad, you can usually get them flushed out, GM actually sells an acid to flush it out but dont leave it in to long
Old February 14th, 2010, 10:59 AM   #8
Slick
Slick's Avatar
Send a message via AIM to Slick
X2 on the Heater Core. I have a 1998 Ranger that I did the heater core in, due to no heat, and no leaks, and it had gotten plugged. I didn't notice the weight aspect of it, but didn't think about it either. Heater core jobs are fun! (sarcastic voice) good luck!
Slick~
Slick is offline   Reply With Quote
Old February 14th, 2010, 11:15 AM   #9
ayytee
all throttle no tallent
try blowing through the core with your air compressor. It can be messy But I've saw it work a time or two.
ayytee is offline   Reply With Quote
Old February 14th, 2010, 11:20 AM   #10
Timmy
Timmy's Avatar
Thanks. If I have to replace the heater core I'll pay someone to do it.
Old February 14th, 2010, 11:22 AM   #11
JohnL
Go until it breaks.
JohnL's Avatar
Honestly it is not that bad. Most places want a round $600-800 to do it.
Good luck hope it works out cheaper for ya.
Old February 14th, 2010, 11:24 AM   #12
blownexploder94
Todd
unhook hoses and put garden hose on it a flush the crap out
Old February 14th, 2010, 12:54 PM   #13
jbsjunk
Little Member
jbsjunk's Avatar
I've done this many times. Always got heat back. Flush from one to the other side till the water comes out clean and flows good.
Old February 14th, 2010, 03:40 PM   #14
Timmy
Timmy's Avatar
Thank you for all the help. I unhooked the lines and used the air compressor. Now I have heat. I will probaablly try the hose line this summer.
Old February 21st, 2010, 01:44 PM   #15
BAD93SBLZR
HILLBILLYWAY
BAD93SBLZR's Avatar
Unhook the heater hoses and run the garden hose through it both ways until clen water comes out in both directions. 99% of the time this will cure the problem on S seires trucks.
BAD93SBLZR is offline   Reply With Quote
Page generated in 0.27017 seconds with 68 queries
