Fuel system leak... - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 13th, 2010, 05:08 PM   #1
AceMon
Could've had a v8
AceMon's Avatar
Default Fuel system leak...
Anyone know what kind of part this is? It's for a 1989 Ford F-250 with a 351w and dual fuel tanks. It's leaking gas from the top and has 4 fuel lines going into it and 2 coming out. I already tried that parts stores and they have no idea as well as pep-boys. Thanks.
AceMon is offline   Reply With Quote
Old February 13th, 2010, 09:20 PM   #2
V8 BroncoII
Buckin Bronco
V8 BroncoII's Avatar
I think they call that a dual function reservoir that acts like a fuel tank selector valve for dual tank vehicles with fuel pumps in each tank.
V8 BroncoII is offline   Reply With Quote
Old February 14th, 2010, 04:11 PM   #3
AceMon
Could've had a v8
AceMon's Avatar
Hey thanks! Now all I gotta do is find a place that sells that thing. Damn fords! (not my truck) I might just have to make a trip to the bone yard. Or We can just bypass it as we don't use the front tanks anyways.
Old February 14th, 2010, 04:30 PM   #4
firehawk
Live Action!
firehawk's Avatar
Yes you can just bypass it. Just follow the lines from the rear tank and bypass that thing and connect them to the lines that go to the motor.
Old February 14th, 2010, 04:54 PM   #5
smasheromalley
smasheromalley's Avatar
I was curious to I looked around and found this
http://www.ford-trucks.com/forums/63...1988-f150.html
this
http://stangler.com/motorsports/arti...alve/index.htm
this
http://www.supermotors.net/registry/2742/66025
BUT I looked up every part number in every thread and source I could find including fordparts.com and never found a single part listed.
Searching rockauto.com gives you a fuel tank selector valve, but only lists a solenoid controlled one. Only thing I can figure is they completely stopped using/selling the passive selector valve (dual function reservoir) because of too many problems/risks and now expect everyone to upgrade to the powered one.
That or call a ford dealer and find out for sure. Good luck
Old February 14th, 2010, 05:02 PM   #6
smasheromalley
Heres another
http://badgerland.ford-trucks.com/fo...ml#post7939560
F1UZ9B263B .. Reservoir & Fuel Tank Selector Valve Assy / Use with gas engines.
F1UZ9B263B replaced: F1UZ9B263A, FOUZ9B263A, E7TZ9B263A.
MSRP: $146.56 // FTE sponsor: Y2KFORDPARTS.COM price: $79.14.
Y2K aka PARTSGUYED.COM = MILLENNIUM FORD in Seattle WA.
if you search for F1UZ9B263B at http://y2kfordparts.com/
F1UZ9B263B $97.64
KIT-FUEL SYSTEM SERV
Add to Cart Contact Us
Can you tell Im bored?
Old February 14th, 2010, 07:03 PM   #7
AceMon
Could've had a v8
AceMon's Avatar
Thanks a lot for the links guys! This is my friends DD and he needs it running asap. I think were just gonna bypass it and call ity a day. Again thanks for all the help!
Page generated in 0.21130 seconds with 44 queries
