help me with transfer case identification - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 12th, 2010, 10:47 PM   #1
jay87
jay87's Avatar
Default help me with transfer case identification
i bought a 82 k10 and im trying to figure out what transfer case it has. i googled a bunch of different ways to identify gm t-cases but i cant figure it out. i had it up on a hoist today the tag on the t-case says model 203 C. but the speedometer cable doesnt hook up on drivers side its on passenger side and its not full time 4 wheel drive. the shift pattern is the same as the np 208 starting from the dash 2wd, 4wd hi, N, then over and back is 4wd Lo. also it does not have a cast iron case.
jay87 is offline   Reply With Quote
Old February 12th, 2010, 11:25 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Pretty sure you have a NP208 that the 8 didn't get fully stamped. A 203 is a huge cast iron full time piece that wasn't used after the mid 70's. The next possible case would be the np241, but these weren't used until 1987.
Old February 12th, 2010, 11:48 PM   #3
jay87
jay87's Avatar
ok i wasnt sure thought somebody on here might know.
Old February 13th, 2010, 06:01 AM   #4
Disturban
Disturban's Avatar
x2 on np208
Old February 13th, 2010, 09:14 AM   #5
Nuggets
I fix stuff!
Nuggets's Avatar
Originally Posted by Disturban View Post
x2 on np208
Did they put anything else in these trucks?
Old February 13th, 2010, 12:03 PM   #6
jay87
jay87's Avatar
i was reading up on them and these came with the np 208, np 203, early trucks had the np 205.
Old February 14th, 2010, 07:37 AM   #7
Disturban
Disturban's Avatar
Models produced after 1980 used the chain-driven NP208 transfer case, and the NP241 after 1988.
Page generated in 0.31560 seconds with 44 queries
