302 and 351 distributor - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2010, 09:24 PM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 302 and 351 distributor
Does anyone know if the 351 uses the same distributor as the 302?
chevyk10 is offline   Reply With Quote
Old February 11th, 2010, 09:28 PM   #2
sandguy356
bronco built for fun
sandguy356's Avatar
NO, they are not the same. Different deck heights=different dizzy
sandguy356 is offline   Reply With Quote
Old February 11th, 2010, 09:48 PM   #3
don4life
don4life's Avatar
i heard something about them being interchangable cause alot of the mustang guys use them cause the 351 firing order is better
don4life is offline   Reply With Quote
Old February 11th, 2010, 10:00 PM   #4
chevyk10
FORD / GM
chevyk10's Avatar
Well I have a 95 F150 with a 302 and it needs a tune-up BAD! I have a distributor to a 351 in good working shape, and was hoping I could just use that instead of going out a buying a new cap and rotor.
Old February 11th, 2010, 10:32 PM   #5
stuckinthemud
stuckinthemud's Avatar
try just puttin the cap an rotor in your distributor?
stuckinthemud is offline   Reply With Quote
Old February 12th, 2010, 12:11 AM   #6
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Pretty sure the distributor doesn't have anything to do with the firing order. It just goes roundy-round a lot. How you put the wires on sets the firing order.
Old February 12th, 2010, 12:19 AM   #7
93liftedzj
ugh, so much misinformation....
simple point, NO they are not interchangeable..
the cap/rotor will be, but thats it...the 351 has a 9.5 " deck height, the 302 is a 8.2 inch deck height..
also, the 351/302 firing order is bullshit...OLDER 302's and NON ho 302s, use the older firing order.
every mustang from 85+ on{may be earlier, i forget the start date} used the 351 firing order, every 302 ho from then on, used the 351 firing order, and the trucks were the same way i beleive in 87 when they went EFI
simple fact, your 95 302 uses the 351 firing order, but cannot use a 351 distributor.
ALSO, do NOT put just any old distributor in your 95 motor, your 95 motor will be roller cam factory, and you MUST use a roller cam gear on the dissy, or you will destroy your motor. if you need a GOOD 302 efi dissy setup for roller cam, PM me, pay for shipping, i will mail you one from my mustang or pickup if your close?, i have several. they have the TFI module and everything.
93liftedzj is offline   Reply With Quote
Old February 12th, 2010, 08:40 PM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
^^^^^ all 100% correct^^^^^^
They also use different size oil pump shafts.
Old February 13th, 2010, 12:15 AM   #9
trooper
trooper's Avatar
351 w dist is identical to the m the c and 429 460 exc. the drive gear
trooper is offline   Reply With Quote
Old February 13th, 2010, 02:00 PM   #10
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Actually, 1-8-4-3-6-5-7-2 is better
Old February 13th, 2010, 02:16 PM   #11
blade262us
blade262us's Avatar
Smile
Not true the 351 Windsor dizzy is the only one to use a 5/16 hex oil pump drive shaft the 289/302 uses a 1/4 hex and the 351C / 351M / 400 / 429 / 460 all share the same distributor with a 3/8 hex drive shaft the Windsor 351 is the odd duck .
blade262us is offline   Reply With Quote
Page generated in 0.45773 seconds with 56 queries
