bravada shaft/ axle - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2010, 05:05 PM   #1
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
Default bravada shaft/ axle
what is intailed in puting a bravada axles shaft and cv into a regular s-series? with my tax return i maybe ifs lifting my jimmy because i found a deal and my neighbor's got a couple laying around. so my thought is if im going into it that far why not get rid of the stupid vacume actuator.
beaterk5 is offline   Reply With Quote
Old February 11th, 2010, 06:18 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
drop in replacement.
Old February 11th, 2010, 06:45 PM   #3
beaterk5
beaterk5's Avatar
sweet so just unbolt from diff re bolt bravada axle and cv and done
Old February 11th, 2010, 07:26 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
yep
Old February 11th, 2010, 07:33 PM   #5
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
You should also look into the 231 t-case swap and maybe even an iron front diff for extra durability.
JohnL is offline   Reply With Quote
Old February 11th, 2010, 07:43 PM   #6
Kevin S
Trying To Become Active
Kevin S's Avatar
Send a message via AIM to Kevin S
You are going to have to pull the passenger side front end apart - the control arms need to be separated from the knuckle, CV Axle pulled out, etc.
When you install the 1 piece Bravada shaft you will want to pull the c-clip off the outer end, otherwise you may experience some binding at full droop, at least that is the case for ZR2's.
Kevin S is offline   Reply With Quote
Old February 11th, 2010, 07:43 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
there was no iron front diff in an IFS truck. he's keeping IFS and just making the front axle fulltime engaged.
Old February 11th, 2010, 07:46 PM   #8
JohnL
Go until it breaks.
JohnL's Avatar
UH..............yes there was , 5 speed ZR2's had them.
Old February 11th, 2010, 07:47 PM   #9
Kevin S
Kevin S's Avatar
There is an Iron Front Diff for the S-Series, but GM doesn't even acknowledge their existance.
They can be found on 1995 - 2003 ZR2's that had a 5-speed tranny, and the NP233 (3-button) transfer case.
Good thread on it over on ZR2USA
http://www.zr2usa.com/mboard/index.php?showtopic=10492
Old February 11th, 2010, 07:48 PM   #10
BlzrNick
Built not bought
BlzrNick's Avatar
im almost positive they had a iron front diff option
BlzrNick is offline   Reply With Quote
Old February 11th, 2010, 07:51 PM   #11
Kevin S
Kevin S's Avatar
Not an option. GM won't even acknowledge they were ever made.
Old February 11th, 2010, 07:51 PM   #12
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
well this is news to me. never ever seen one and them were pretty rare it seems.
Old February 11th, 2010, 07:54 PM   #13
JohnL
Go until it breaks.
JohnL's Avatar
They are definitely real , I had one but sold it when I moved.
Old February 11th, 2010, 07:58 PM   #14
Kevin S
Kevin S's Avatar
John's an idiot
:P
Old February 12th, 2010, 06:02 AM   #15
beaterk5
beaterk5's Avatar
im getting every thing off the truck he is doing a sas it's from liftedjimmy4x4 on so every thing will be out and easily accesable
hmm i wand an iron diff but i think sas would be better but why couldnt of you kept it john im just down the road right outside mason
also not related to it but how dose the exhaust need modded for the kit? just for front shaft clearance? it's a 5" bds
Page generated in 0.28085 seconds with 68 queries
