Anyone tried rebuilding SD unit bearings? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2010, 03:37 PM   #1
bronco4-play
Do it like you mean it
bronco4-play's Avatar
Default Anyone tried rebuilding SD unit bearings?
It looks like they can be disassembled with a spanner wrench. Anyone tried getting the bearings from an industrial bearing supplier and rebuilding one yourself?
This is on an 02, F350
bronco4-play is offline   Reply With Quote
Old February 12th, 2010, 07:42 AM   #2
fsumotorhead
N8KVB
fsumotorhead's Avatar
if you have a junk one you're going to replace, i think the worst that could happen is you are out your time and have to buy one anyway.
but my guess is no
Old February 14th, 2010, 09:02 AM   #3
Paperman
Paperman's Avatar
When you get into one you see why they are not repairable. They are built opposite a normal axle. The inner race is what turns and is also the wheel flange. The outer race is actualy made as part of the mount. That is the part with the four studs is ground to be the outer race.
Paperman is offline   Reply With Quote
Old February 14th, 2010, 02:17 PM   #4
bronco4-play
I was afraid it was something like that. Thanks for the info.
Page generated in 0.18884 seconds with 35 queries
