Ram Brake Lights - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2010, 03:08 PM   #1
Stev5816
Stev5816's Avatar
Default Ram Brake Lights
I have a 2006 Ram 1500 Big Horn
My problem is that the 2 brake lights on the bed are not working. The bulbs are good, they work and everything else works...flashers, signals, even when i turn the headlights on they light up...they just dont work when i hit the brake. They light on top of the cab works when i hit the brake.
The fuse that makes the most sense is the one that says "brake swtch / chmtl / stop LT" or something like that. That fuse is good.
Im thinking that it could be another fuse or maybe that my trailer wiring has a short in it....
any suggestions would be great...thanks
Stev5816 is offline   Reply With Quote
Old February 11th, 2010, 03:14 PM   #2
Redneck4Life
F*#% It! BLOW IT UP
Redneck4Life's Avatar
Send a message via AIM to Redneck4Life Send a message via MSN to Redneck4Life
strip part of a wire an screw it in with the bulb then put the other end as a ground. the true deffinition of "insert racial slur here" rigged.
i did this with my jeep just messing around with it one day works fine now
Redneck4Life is offline   Reply With Quote
Old February 12th, 2010, 10:45 AM   #3
gmotox
gmotox's Avatar
test the circuit at the rear lights with circuit tester first. check the contact on the bulb and make sure they are good, I have had the thin concact on the bulb melt into the plastic and not make good contact.
did you try new bulbs or just assume they are good?
Old February 12th, 2010, 12:30 PM   #4
Stev5816
Stev5816's Avatar
The bulbs are good. they light up fine when the turn signals / flashers are on...when i turn the lights on, both the top and bottom bulbs on both sides light up to
Old February 12th, 2010, 03:42 PM   #5
gmotox
gmotox's Avatar
bulbs have two filaments. On my 2005 Ram the top lights are turn signals and the bottom are brake, both are running lights also. check the bulbs first, then check for power at the tail light plug.
Old February 12th, 2010, 09:13 PM   #6
hamsmotorsports
hamsmotorsports's Avatar
the turn signal/ multifunction switch is most likely bad, the brake light switch is good because the third light works, change that t/s switch and it will fix it
hamsmotorsports is offline   Reply With Quote
Old February 14th, 2010, 03:44 PM   #7
gmotox
gmotox's Avatar
Is this fixed yet? what was the problem?
Page generated in 1.94930 seconds with 44 queries
