SBC carb help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2010, 12:24 PM   #1
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Default SBC carb help
Well I just bought a brand new eddelbrock 1406 carb to put on my 350 and the guy I called at edelbrock said they dont recomend using the 1406 on the performer rpm intake I have. He said it would cause idle problems because the intake is so large it wouldn't be able to get enough fuel to the engine.
the 1406 is 600cfm where the 1806 he recomended is 650cfm. I've talked to a couple stores hee that sell them and all have said that sounds like crap and they have sold the 1406 with the performer rpm and have not ever had any problems.
Has anyone ran this carb/intake before? Am I going to have problems with it? Thanks for the info.
lastmanstandin is offline   Reply With Quote
Old February 11th, 2010, 12:52 PM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
The Edelbrock 600 should be more than enough. I ran the same settup and had to rejet the primaries down one size to get it right. Those carbs are easy to tune, read the manual a few times before you adjust anything. Install the off road needle and seat to keep it running good off road.
Old February 11th, 2010, 01:26 PM   #3
lastmanstandin
EvL 1
Thanks for the info. I decided I'm going to take this one back and get the 1826 carb instead. It has the off road needle and seat already and the guy from edelbrock said it would be a good fit for the performer RPM intake that I have.
Unless theres a reason I shouldn't use this one......
Old February 11th, 2010, 01:35 PM   #4
BigBlockBlazer
Axle breakin' 101
Sorry I can't give advise on what one to use because I don't know anything about your motor. If the Edelbrock guy says that's the one, I would listen to him. Hopefully you have a matched cam for the other parts or its a waste.
Old February 11th, 2010, 01:47 PM   #5
lastmanstandin
EvL 1
ya the guy said that was the one so hopefully it works for me....
Old February 11th, 2010, 08:13 PM   #6
lastmanstandin
EvL 1
Anyone else have any input on this?
Old February 11th, 2010, 09:43 PM   #7
If you're planning on running it off road, don't waste your time on an Edelbrock. Go with the Holley Truck Avenger. There is no comparison.
(speaking from experience with both)
Old February 12th, 2010, 12:08 AM   #8
lastmanstandin
EvL 1
Damn too late....I allready ordered the edelbrock. Well I'll know next time.
Old February 12th, 2010, 08:58 AM   #9
BigBlockBlazer
Axle breakin' 101
My experience with the Edelbrock 600 was flawless. Take the time to tune it to your motor and it should perform good. I know several people who have run both carbs and like one or the other. Ask Jason Hull about his Truck Avenger and you'll get a different story than rino's. Sorry Jim I had to add my two cents, my Edelbrock ran great.
Old February 12th, 2010, 10:21 AM   #10
lastmanstandin
EvL 1
Well I ended up with the edelbrock 1826 off road carb. Going to try and have this beast running by this weekend. Thanks again.
Old February 12th, 2010, 12:03 PM   #11
No offense taken. I screwed around with my Edelbrock for 2-3 years. Did the spring loaded needle & seats, changed floats, changed metering rods, changed jets. It was inconsistent and no matter what it didn't like angles. When I lowered the float low enough to work good on hills, I would run out of gas on full throttle assaults. I couldn't win.
I also had problems with my first Truck Avenger. I bought one right after they came out. I had trouble with it flooding over. After back and forth a couple times, they came out with an upgraded version. They swapped out a year old carb for a brand new one, no questions asked. After that one got tuned, never a problem again. I wonder if Jason had an earlier one? I'm guessing he did because he's been running propane for years.
I'm sure there are Edelbrock success stories. Just not me.
Old February 12th, 2010, 01:27 PM   #12
lastmanstandin
EvL 1
Well I hope mine is a success story. I need the throttle/kickdown bracket and it's going on.
Page generated in 0.21029 seconds with 59 queries
