Wanted 1976 F250 longer pitman arm - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 11th, 2010, 10:41 AM   #1
coreyws
coreyws's Avatar
Default Wanted 1976 F250 longer pitman arm
I lifted my 1976 F250 now I need a longer pitman arm. Its not really a dropped pitman arm just needs to be longer. Does anyone have one they can part with. Thanks
coreyws is offline   Reply With Quote
Old February 15th, 2010, 08:09 PM   #2
Familyman
Familyman's Avatar
As far as I know there is no such animal. How much did you lift it? I am at about 4" running 36" with the stock ram set-up with no problem. If you indeed have a high boy it can be converted to the 77-1/2 -79 set-up. Good luck
Familyman is offline   Reply With Quote
Old February 15th, 2010, 09:41 PM   #3
coreyws
coreyws's Avatar
It has manual steering on it right now. No power steering what so ever. I lifted it six inches. Thanks
Old February 16th, 2010, 09:07 AM   #4
Zebrafive
You need to move the steering arm on the axle up, not a longer pitman arm
Zebrafive is offline   Reply With Quote
Old February 16th, 2010, 01:04 PM   #5
coreyws
coreyws's Avatar
how do i do that or what do i do it with. Thanks for your help.
Old February 17th, 2010, 08:20 AM   #6
Zebrafive
Longer studs and a block.
Page generated in 0.22862 seconds with 41 queries
