98 1500 4x4 whine - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 10th, 2010, 08:18 PM   #1
ericschmidt
ericschmidt's Avatar
Default 98 1500 4x4 whine
My truck pulls great in 4wd. But when I'm going down the road and I take my foot off the gas, it seems to whine. Under accel. it seems to go away or at least get very quiet. Any ideas?
ericschmidt is offline   Reply With Quote
Old February 10th, 2010, 08:20 PM   #2
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
U-joints or the slip in the front shaft.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old February 11th, 2010, 11:16 AM   #3
sonic
sonic's Avatar
Pinion bearings
sonic is offline   Reply With Quote
Old February 11th, 2010, 04:19 PM   #4
ericschmidt
I'm thinking it's something in the front axle also. I'll pull the driveshaft and see if it clears up. 4wd seems to work just fine otherwise, except it takes forever for it to shift in and out of 4wd. It may be that it hasn't been used enough since it sat for a year and a half before I bought it. It seems to be getting better the more I use it, I think...
Old February 15th, 2010, 05:03 PM   #5
crazeejay
Crazy Canuck
crazeejay's Avatar
Pull off the actuator on the axle to make sure there is no crap inside that would restict the fork. I checked mine and had a bunch of ice in there.
crazeejay is offline   Reply With Quote
Old February 15th, 2010, 10:34 PM   #6
ericschmidt
Thanks, I'll check it out!
Old February 15th, 2010, 10:45 PM   #7
deerebowtie
Unchained
deerebowtie's Avatar
check fluid level in front diff and u-joints.
Old February 16th, 2010, 06:41 AM   #8
mopar96
Get Some!!
mopar96's Avatar
Dodges with higher mileage have been know to have a whine in it from the differentials. Mine has done it for the last 5 years. Nature of the beast if you do your checks and find nothing.
mopar96 is offline   Reply With Quote
Old March 28th, 2010, 09:41 AM   #9
cherokee chief
cherokee chief's Avatar
Depending on how many miles are on the Tcase the chain in the case could have stretched and whine on coast down.
cherokee chief is offline   Reply With Quote
Page generated in 0.30345 seconds with 50 queries
