hydro boost vacuum?? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 9th, 2010, 08:36 AM   #1
jamestheron08
Default hydro boost vacuum??
hey guys i have a v10 2001 with hydro boost brakes but on the back of my intake plenum theres a open vacuum port where the vacuum booster would hook to whats supposed to plug in there? its wide open sucking air damn dealer don't even know the past owner did remove the big air pump lines for some reason but the pump is still being driven could that have something to do with it?
heres a link to a pic i took it's right above the trans tube the orange pointer is touching it
http://i940.photobucket.com/albums/a...0207001200.jpg
jamestheron08 is offline   Reply With Quote
Old February 9th, 2010, 10:18 AM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I thought it was suppose to just be a large cap/plug over that.
Old February 9th, 2010, 10:29 AM   #3
PavementPounder
PavementPounder's Avatar
The Dealer can't not know what is supposed to be there. The shop manual would contain that information. I don't have my V10 handy, so I can't go check.
What happens when you stick your finger in it?
Old February 9th, 2010, 10:56 AM   #4
jamestheron08
when i cover it the engine stalls but starts back up i feel a big gain in power but at WOT my heat vents go from defrost to mid . i called the dealer and they looked through there manuals and couldn't find anything I'm only getting 5.5 mpg and smelling real rich to it's the out side port next to the speed control and the cad vacuum port
Old February 9th, 2010, 11:11 AM   #5
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Yeah- I think that I'd be looking up another dealer..... that's not right. If you are in the least bit framilliar with reading schematics, there should be a vaccum routing schematic under the hood somewhere- maybe on the radiator support. That MAY contain what you are looking for.
Old February 9th, 2010, 11:29 AM   #6
jamestheron08
yeah its there and says it hooks to the brake booster lol but i dont have one
Old February 9th, 2010, 11:30 AM   #7
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Nice!!!!
idiots.....
Old February 9th, 2010, 11:32 AM   #8
PavementPounder
I'd just plug it, then.
Old February 9th, 2010, 01:10 PM   #9
nosights
nosights's Avatar
I would plug it and go from there. That would cause a high idle and a bunch of other stuff and the computer would compensate for it...most likely that is why it stalls out. Cap it and let us know of the changes.
PM me directly if you need more info and I can grab a tech and/or look up the schematic.
I am quite certain all you need to do is cap that port.
nosights is offline   Reply With Quote
Old February 9th, 2010, 02:52 PM   #10
jamestheron08
OK i capped it and went for a ride then let it sit and idol for 5 min there was dark smoke raw fuel smell very rich so i un plugged it any other ideas I'm so lost
Old February 9th, 2010, 02:57 PM   #11
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
Something else is missing here...... Maybe an intake manifold leak or something...... Not having a vaccum leak should make it run more rich, but not that rich.... maybe a combination of that and a timing advance to make up for it???? I'm scratching my head here. Any check engine light on? The dealership should at the very least be able to hook up their OBD2 scanner and see what specifically it's affecting besides fuel mixture and idle.....
Old February 9th, 2010, 03:20 PM   #12
jamestheron08
nope no engine light the dealer told me to bring it up there but they want 100.00 to even look at it i thought i would ake here first I'm broke
Old February 9th, 2010, 03:33 PM   #13
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Are you maybe missing a PCV valve?
Old February 9th, 2010, 03:49 PM   #14
nosights
nosights's Avatar
I think you either have multiple issues or yoou are not giving the computer enough time to correct the mixture. It generally takes a good number (3-30) key cycles/warm ups to learn any changes. That is a non mas airflow engine I believe and thus learns a bit slower. Plug it and go for a ride/ try it for a few days.
As for the codes...Auto Zone and the other big chain stores scan for free.
Dan
Old February 9th, 2010, 05:50 PM   #15
jamestheron08
ok ill plug it for longer but it was so rich i got worryed i mean it was bad...no engine codes are in the system autozone did a scan and there was 0..
Old February 9th, 2010, 10:13 PM   #16
Yota Bill
if it is overfueling as much as you describe, that is not something the computer will correct for, that is another problem...I would suggest not running it for long if it is overfueling to the point of black smoke and the smell of raw fuel...that could easily be raw fuel in your exhuast, which could lead to a fire
Old February 9th, 2010, 10:33 PM   #17
smasheromalley
smasheromalley's Avatar
cap the hose and disconnect the battery for a few minutes to delete the fuel trim. Reconnect the battery and give er a shot?
Matter of fact, disconnect the battery for a while anyhoe and take it back to autozone to see if the computer returns a P1000 like it should
Old February 9th, 2010, 10:38 PM   #18
smasheromalley
BTW your v10 is an 8.0 liter engine. And with hydroboost brakes Im assuming its in a 1ton dually with a 4:10 or 4:56 gear in a dana 80 rear. I would think 5.5mpg isnt far off from normal
Old February 10th, 2010, 06:12 AM   #19
jamestheron08
yeah its a dually 355 gear i should be getting around 10 mpg
Old February 11th, 2010, 09:46 AM   #20
jamestheron08
OK so plugged it and reset the pc. drove for 35 miles with no change my heat vents are changing from defrost the face by them selfs to......still no codes here is a better pic from my book see where the circle is TO BRAKE BOOSTER thats the port I'm talking about. the truck does have a k&n CAI do you think that like hooked to the stock air cleaner?
the pic of my engine is not so good so i posted this one.no change i was talking about still smoking and real rich.
Page generated in 0.75455 seconds with 83 queries
