Need help; my ramcharger won't start - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 22nd, 2006, 02:06 PM   #1
dodgegirl
dodgegirl's Avatar
Unhappy Need help; my ramcharger won't start
When I turn the key the starter engages but won't turn the motor over. Any ideas on what could be the problem? It acts like there is not enough power getting to the starter but the battery is fully charged and everything else works such as lights, radio, etc.
dodgegirl is offline   Reply With Quote
Old July 22nd, 2006, 02:25 PM   #2
Toivo
Feel lucky?
Toivo's Avatar
The starter could very well be shot. My mud truck did that, then I threw another starter in it and it was fine. It could also be your starter solenoid shorting out, Dodge wiring tends to suck.
Old July 22nd, 2006, 02:28 PM   #3
dodgegirl
dodgegirl's Avatar
Thanks, I will try that and see what happens.
Old July 22nd, 2006, 09:58 PM   #4
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Do the lights dim when you try to crank it over? Do they go out completely?
Old July 22nd, 2006, 11:03 PM   #5
dodgegirl
dodgegirl's Avatar
Went and got a starter and starter relay. Now the RC will start, but not charge. When I disconnect the battery it wil die and then when the battery is reconnected it will start back up. Yes the lights do go dim but don't completely go out.
Old July 22nd, 2006, 11:11 PM   #6
88mudder
In the band!
alternator is bad.
Old July 23rd, 2006, 03:30 PM   #7
dodgegirl
dodgegirl's Avatar
Took the alternator in and had it checked and it was bad; but I luckily got it replaced for free since that one was only 3 months old. Now my ramcharger is up and running again. Thanks to everyone for all their help.
Page generated in 0.31217 seconds with 44 queries
