Ford 9" "Nascar" Detroit locker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 8th, 2010, 07:57 AM   #1
MJ_Silver_1988
MJ_Silver_1988's Avatar
Send a message via AIM to MJ_Silver_1988
Default Ford 9" "Nascar" Detroit locker
Has anyone on here ever heard if the Detroit Lockers on ebay are any good that are supposedly taken out of the Nascars. Im redoing my gear set (R&P shot) and figure while its apart i might as well throw one in if there worth it. There only $300.
http://cgi.ebay.com/ebaymotors/NASCA...item2eaae10ce1
MJ_Silver_1988 is offline   Reply With Quote
Old February 8th, 2010, 08:24 AM   #2
twelve
twelve's Avatar
I don't know anything about it but it looks pretty cool. If you buy one keep everyone informed on how it works etc. .
twelve is offline   Reply With Quote
Old February 8th, 2010, 09:00 AM   #3
95geo
newbie
95geo's Avatar
There was some discussion a while about them on pirate. I remember something about them being setup a little differently than the standard models you would buy. I dont remember exactly what it was but a search in gen 4x4 should get you some answers.
Old February 8th, 2010, 03:17 PM   #4
mean_greenEXJAY
YJ now
mean_greenEXJAY's Avatar
If I remember correctly, they are different in the way they unlock. I think power is always going to the outside tire and the inside tire unlocks in turns. So it doesnt provide full differential action and right turns might be weird. But I wouldnt know if that locker is like that.
Old February 8th, 2010, 04:35 PM   #5
joe_jeep
welfare wheeler
joe_jeep's Avatar
i had one in my last tj. got it used for 180 shipped from dei racing through ebay.
the difference is in the internal spring rate. mine had a brand new set of black springs.
it was locked up real tight. it would almost never ratchet. i was told they could be changed out for softer springs, like a detroit soft locker would have. they use a real soft spring rate for racing. it would unlock really easily. i was also told some use a weird ring and pinion gear, others do not. depends on how it was made. mine used standard gears.
im no locker expert, just what i was told?? take it for what its worth.
Old February 8th, 2010, 04:39 PM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
I notice the description says "light weight". There are some ultralite lockers out there that are made for use with an ultralite gear set. Might want to make sure it's not one of these.
Old February 8th, 2010, 05:15 PM   #7
If I hadn't read it, and known you posted in it, I'd have had a hard time finding it...
Pirate4x4.Com Bulletin Board - View Single Post - First Super 14 Bolt Housing rolls off the line...
Supposedly, they are unlocked until you are on the gas.
Old February 8th, 2010, 06:03 PM   #8
95geo
newbie
95geo's Avatar
To be honest with you, I couldnt remember where it was exactly and I didnt feel like searching for 20 minutes to find it. Good thing you dug it up!
Old February 8th, 2010, 09:31 PM   #9
MJ_Silver_1988
i think the "light weight" is in there bc of the scalloped edge where the ring gear bolts...how instead of being round the metal is cut out between the holes. but again i could be wrong just trying to find ppl experiences thanks for the help
Old September 14th, 2011, 11:13 AM   #10
PatriotWheeler
Default Do you want to ever turn right?
Just be cautious of anything called a "Race Locker". Many are only half of a locker! To save weight, the left side "clutch" is left out of many designs. Therefore, only the right axle shaft is able to disengage in corners. They are also not a "soft locker". The race teams want the re-lock immediately for traction out of corners. The weight savings someone mentioned is (mostly) from the scallops around the ring gear bolts holes (as someone else speculated).
Point - A typical oval track "race locker" of Nascar style is a very bad choice for off-road driving.
PatriotWheeler is offline   Reply With Quote
Old September 15th, 2011, 08:55 PM   #11
MJ_Silver_1988
since i posted this i have had one installed in my Jeep...i love it...it locks up instantly when i need it but still unlocks easily when im driving the street and rounding corners...for the price invested i couldnt be happier
Page generated in 0.26869 seconds with 57 queries
