thaw frozen ground? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2010, 09:11 PM   #1
camccardell
tiger blood
camccardell's Avatar
Default thaw frozen ground?
Wasn't sure exactly where to post this, so I figured the pub was good a place as any.
Long story short, I need to thaw the ground by my garage to get to the utilities. I tried digging with my pickaxe and broke the damn conduit so I need to really fix it now.
Anyone have any ideas on this?
I tried throwing down some charcoal and getting it hot with a fan, but that only softened up about 2 inches of dirt.
Any ideas would be appreciated.
Old February 7th, 2010, 09:17 PM   #2
Chief Brody
Get off my lawn.
Chief Brody's Avatar
You might as well wait 'till spring.
Chief Brody is offline   Reply With Quote
Old February 7th, 2010, 09:18 PM   #3
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
call a concrete company and see if you can rent there heat blankets
Old February 7th, 2010, 09:26 PM   #4
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Use your plasma Cutter. That would be awesome!
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old February 7th, 2010, 09:27 PM   #5
OVoXO
OVoXO's Avatar
When I had to dig out my septic tank cap a few winters ago, they told be to build a fire on it.
OVoXO is offline   Reply With Quote
Old February 7th, 2010, 09:28 PM   #6
jeepinRRT
jeepinRRT's Avatar
Maybe copious amounts of hot water on some sort of tank with no bottom?
Thats all I got.
how deep are you trying to go and how long of an area?
jeepinRRT is offline   Reply With Quote
Old February 7th, 2010, 09:47 PM   #7
FlatFender
Tap Tap Splat
FlatFender's Avatar
If you already broke the stuff, keep going with the pick.
Old February 7th, 2010, 09:49 PM   #8
fukkinrizzo
Chrome Trucker Chicks Rul
fukkinrizzo's Avatar
x2
or axe
fukkinrizzo is offline   Reply With Quote
Old February 7th, 2010, 09:52 PM   #9
xj97sport
atv rider
xj97sport's Avatar
best bet
Old February 7th, 2010, 10:28 PM   #10
Yota Bill
burning barrel set just an inch or two off the ground, and get rid of some of Kodiaks trash for him at the same time
put a screen over the top, and maybe a piece of flat steel to keep the ashes away from the garage, and keep the fire going for a while...but I wouldnt get too far away from it since its right next to your garage
Old February 7th, 2010, 10:34 PM   #11
techman
With as cold as it has been, if this is an area where you walk or drive, the frost could be a couple of feet thick.
techman is offline   Reply With Quote
Old February 7th, 2010, 10:35 PM   #12
gmotox
gmotox's Avatar
When digging footings in the winter I have taken steel barrels cut in half length wise, placed them on the footing area and overlapped them a few inches and placed a torpedo heater in one end, basically creating a heat tube layed in the ground..
A torpedo heater and some car hoods or sheet metal would do what you need.
You can also rent earth heaters but they are spendy.
Old February 7th, 2010, 10:45 PM   #13
lauriat
lauriat's Avatar
Have a party and put a funnel in the wall.
lauriat is offline   Reply With Quote
Old February 7th, 2010, 10:53 PM   #14
blownexploder94
Todd
blownexploder94's Avatar
Lots and lots of your used anitfreeze. lol J/K
Old February 8th, 2010, 12:01 AM   #15
Muddyfun73
Yooper
Muddyfun73's Avatar
I second the torpedo and 55 gallons drums. Had to dig our septic up one winter and that's what the septic guy recommended. Worked pretty good. We put some old moving pads on top of the barrels to keep more of the heat in.
Muddyfun73 is offline   Reply With Quote
Old February 8th, 2010, 12:03 AM   #16
scramblerman72
Moonlight stomper
scramblerman72's Avatar
Send a message via AIM to scramblerman72 Send a message via MSN to scramblerman72 Send a message via Yahoo to scramblerman72
yep torpedo heater and if its a larger area just tarp it off and let it rip for a long while,
scramblerman72 is offline   Reply With Quote
Old February 8th, 2010, 05:47 AM   #17
55.0.0
Default frozen
we at the dpw use 300,000 propane torch they sell them at hardware stores or home depot hook it up to your 20lb tank. They also advertize them as burning weeds on side walks and ponds. We use them to find water shut off's and grave lot's
55.0.0 is offline   Reply With Quote
Old February 8th, 2010, 05:53 AM   #18
tsaguy
Semper Fidelis
tsaguy's Avatar
My dad once used an aluminum trash can, started a large bag of charcoal on fire, and let that burn for 8 hours. Vented with a small block on one side lifting the edge of the can to allow for oxygen. the reflective properties of the aluminum helped to thaw it out to get past the frost line.
tsaguy is online now   Reply With Quote
Old February 8th, 2010, 09:20 AM   #19
groundhog
groundhog's Avatar
put aton of salt down where you need to dig! Aco had it on sale this past weekend for 50lb bags, a bag will go about 3 ft. Let sit for 3-4 hrs should be good!!!
groundhog is offline   Reply With Quote
Old February 8th, 2010, 09:33 AM   #20
kickstand
circling the drain
kickstand's Avatar
all you need is water....doesn't even have to be warm water, turn the hose on and start digging, it'll be muddy, and slow going, but all you need is a slow trickle out of the house.
Pick axe, shovel, and water....oh, and elbow grease...get at it.
Page generated in 0.36809 seconds with 82 queries
