Need Help on lift kit asap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2010, 01:41 PM   #1
94transam25th
94transam25th's Avatar
Default Need Help on lift kit asap
Ok so friday night me and a couple buddies went to put the lift on my 2000 f250 and it was a nightmare. We spent 15 hours working on it and right now have the track bar rigged because we couldnt get it to line up so had to put smaller bolts to get them through. We also couldnt get the stock pitman arm off so the drop still needs to go on.
We got the springs and shocks on good tho
after dealing with this all night we decided to say screw it and didnt even attempt the back the back lift is going to be blocks and a leaf that came with the kit. I need to order the carrier bearing drop also
I am absolutely sick of looking at the truck right now and was just wondering if there is someone on here that needs to make a bit of money and would be able to help me out
Mods can moeve this if they want just wanted to get some more views on it possiblt
94transam25th is offline   Reply With Quote
Old February 7th, 2010, 01:44 PM   #2
special ed
Pickup Agent
special ed's Avatar
Pitman arm pullers are cheap, and every parts store has them?
special ed is offline   Reply With Quote
Old February 7th, 2010, 01:51 PM   #3
firehawk
Live Action!
firehawk's Avatar
You might need to use a ratchet strap to get the track bar into position.
Attach one end to the axle and one to the frame and start ratcheting it until the holes in track bar and mount line up. Put bolt in and tighten it up.
Old February 7th, 2010, 03:16 PM   #4
94transam25th
we did the lift up in almont in a friends barn... the pitman arm puller autozone assured me was gonna be big enough definitely was not
Old February 7th, 2010, 03:17 PM   #5
94transam25th
you have pm
Old February 7th, 2010, 03:20 PM   #6
Bishop
Bishop's Avatar
there's your problem....
maybe not but if it fits, put a lot of tension on it the wack it with a hammer. the arm NOT the puller. and repeat until it comes off.
Old February 7th, 2010, 03:21 PM   #7
kickstand
circling the drain
kickstand's Avatar
that might work, but its a lot easier to have someone turn the steering wheel back and forth. This will push the truck side to side while the axle stays in place.
Pitman arm, get the right sized puller, crank it down with the impact gun, then smack it with a hammer, then re-tighten, smcak with hammer, repeat until it pops loose....if no impact you can do it with a ratchet, it just may take longer. Don't add a pipe or anything for leverage, just tighten the ratchet as tight as you can by hand, smack it, repeat.
the back should be pretty easy, shocks, blocks, and add a leaf. Assuming you got new u bolts just cut the old ones off and go to town.
Old February 7th, 2010, 05:04 PM   #8
hosejockey4506
Visiting Admin
hosejockey4506's Avatar
x1.5 just have some one turn the wheels while the truck is on the ground, Was there a trackbar relocation bracket or a longer trac bar supplied????????
Old February 7th, 2010, 05:15 PM   #9
blownexploder94
Todd
blownexploder94's Avatar
was forced to use an autozone one on my buddies superduty cuz its what he brought, so i put it on the grinder and opened it up, worked just fine
Old February 7th, 2010, 05:30 PM   #10
94transam25th
it came with track bar relocation brackets i got from mudbillyredneck on here.... we tried doing the turn the wheels method and still couldnt get it to line up right tho
Old February 7th, 2010, 06:38 PM   #11
94transam25th
im sick of looking at the truck anddont have anywhere to work on it until next weekend. Is there anyone in my area interested in finishing it for cash?
Old February 7th, 2010, 07:17 PM   #12
bigblockford79
Big Block Ranger
bigblockford79's Avatar
Regular pitman arm pullers(the 2 piece ones AZ sells) WILL NOT work on Ford truck, the arms are too big to even fit in the puller. I get around this by renting their larger 3 jaw puller and only use 2 of the jaws. Make sure the puller can be used as a 2 jaw before you take it home, you will need the jaws directly across from each other.
Good Luck, if I was closer to you I would give you a hand.
Old February 7th, 2010, 10:04 PM   #13
94transam25th
nobody wants to make some quick cash... if i cant line something up im gonna have to take it to mumbly to get finished on thursday
Page generated in 0.25299 seconds with 62 queries
