motor swap/ backdate question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 7th, 2010, 12:13 PM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default motor swap/ backdate question
Here are the questions I have:
I have a 1993 dodge 360 magnum motor with tb fuel injection, im going to be swapping this motor into a 1986 dodge ramcharger but i really dont want all the computer controlled bs. I was wondering if its possible to put a late model intake manifold instead of the tb unit and also a late model distributor out of my old 360 onto the 360 magnum and will it cause any problems? I was hoping to run the 360 magnum heads but i could put my old 360 heads if i had to. I was also planning on bolting it up to a late model 727 trans so i didnt want to have to run the crank shaft position sensor which is another reason for eliminating the computer. I just want to know if it is possible to back date a throttle body injected motor to carb and if so what things would i have to change or possibly fix to make the motor run? thank you for any info
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old February 7th, 2010, 04:28 PM   #2
269bigoldodge
269bigoldodge's Avatar
You will need to get an aftermarket 4bbl intake for a magnum and you will also need to get a distributer for a small block, mopar sells a dist kit that has the wiring, dist, ballest and ecu. you will also need to use the magnum flexplate.
269bigoldodge is offline   Reply With Quote
Page generated in 0.17814 seconds with 29 queries
