Towing a Ford Automatic - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2010, 02:33 PM   #1
wmmalett
Default Towing a Ford Automatic
I just bought a 93 Ford Ranger 4X4 4.0 Automatic. My question is: Can I tow this thing on a tow dolley without doing any damage to the transmission or should I disconnect the driveshaft at the rear end before pulling.
Thanks,
Bill
wmmalett is offline   Reply With Quote
Old February 6th, 2010, 02:58 PM   #2
bigblockford79
Big Block Ranger
bigblockford79's Avatar
To be on the safe side you always want to disconnect the drive shaft on any automatic that you can't put the tcase into neutral.
That being said if you're only going a couple miles at low speed you;ll be okay.
Edit: I just checked my haynes manual and it says (assuming you have an electric shift tcase) -
-release the park brake
-put trans in nuetral
-tcase in 2H
-front hubs unlocked
*limit speed to 35 mph and distance to 50 miles
Old February 6th, 2010, 03:33 PM   #3
wmmalett
Thanks. Looks like I'm disconnecting the driveshaft. I have to haul it over 100 miles.
Old February 10th, 2010, 12:09 PM   #4
fsumotorhead
N8KVB
fsumotorhead's Avatar
ford actually has a neutral tow kit for these, it's just a switch that moves the t-case into neutral, for flat towing behind RVs.
Pulling the shafts is always a prefered method, but is a PITA
Old February 10th, 2010, 12:14 PM   #5
jeepitupyo
MMM Shrimp Slushy
jeepitupyo's Avatar
Just put it on the dolly backward.
05 Silverado Crew Z71
00 XJ BDS Long Arms 35's
Beelby & Sons Towing
Old February 18th, 2010, 12:43 PM   #6
udjlax
udjlax's Avatar
Send a message via AIM to udjlax
i put a 2wd s10 backwards on a toll dolly, it was fine till it came to backing it up. it was a pain in the ass. the front tires wanted to turn opposite of the trailer, so it kept binding. so my buddy sat in the s10 and steered that while i backed up the tow vehicle and dolly, it was quite a site.
udjlax is offline   Reply With Quote
Page generated in 0.38374 seconds with 41 queries
