rear brake drum removal 95 k2500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 6th, 2010, 12:05 PM   #1
don4life
don4life's Avatar
Default rear brake drum removal 95 k2500
How do i get rear brake drum off it's a 95 k2500 suburban. Do i just keep beating on it till it comes free or do i have to remove the axle retaining plate that is their???
don4life is offline   Reply With Quote
Old February 6th, 2010, 12:13 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
you have a full floater? does the axle bolt through the center of the hub and have 8 bolts on the outside flange? if so you have to remove the flanged axle first. then remove the thin snap ring that hold the lock key in place. after the key is out you can spin the nut off ( Use a short pair of needle nose that I remove the spring clip and key with) then once all thats out you can pull the hub and drum together. should take about 2 minutes. and if the shoes are stuck you will need to back off the adjuster.
Yetti
Old February 6th, 2010, 12:31 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
have you tried backing the self adjuster off? on those trucks even with a FF axle the brake drum is not pressed onto the axle hub. i just did a set on a 94 K2500 last week. some beating and banging should get it off.
Old February 6th, 2010, 02:51 PM   #4
Disturban
Disturban's Avatar
I think all 3/4 ton Burbans come with SF rear ends...just have to back off the adjusters and beat it with a hammer.
Old February 6th, 2010, 02:52 PM   #5
kj kyle
kj kyle's Avatar
they make a puller.
puller + impact + heat = success.
kj kyle is offline   Reply With Quote
Old February 6th, 2010, 03:23 PM   #6
don4life
don4life's Avatar
yah it was i floater so i just pulled axle and the whole hub and drum..
Thank you guys again
Old February 6th, 2010, 05:05 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
not true. all the diesels come with FF axles and i believe it was an option on gassers.
Old February 7th, 2010, 09:33 AM   #8
Disturban
Disturban's Avatar
Like I said (I THINK) Good info though...do you know if any came with a dana60 up front or did the diesels still use 44's and 10 bolts?
Old February 7th, 2010, 11:53 PM   #9
don4life
don4life's Avatar
im pretty sure its not a 10 bolt
Old February 8th, 2010, 08:32 AM   #10
tipster49424
Keep on Truckin...
tipster49424's Avatar
My 1994 3/4 ton diesel burban is IFS
tipster49424 is offline   Reply With Quote
Page generated in 0.20077 seconds with 53 queries
