One Ton XJ BUILD (Updated wheeling PIC'S) - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 30th, 2011, 04:00 PM   #141
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
bbrancheau is offline   Reply With Quote
Old October 30th, 2011, 04:02 PM   #142
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
here is new location of axle now i have to make room for tire up travel. most likely bump stops. maybe some cutting want to keep the XJ look still side makerlight wise
Old October 30th, 2011, 04:21 PM   #143
Offroadian
seasoned
Nice build.
Offroadian is offline   Reply With Quote
Old November 13th, 2011, 05:29 PM   #144
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Little update. burned in the rear spring perches and bolted down.
Old November 13th, 2011, 05:31 PM   #145
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
I know i will catch some $hit for this but i redrilled springs 3" back and pined them. springs are worn in about time for new ones but budget wont allow right now so had to make due.
Old November 13th, 2011, 05:33 PM   #146
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
here is the new stance.
Old November 13th, 2011, 05:35 PM   #147
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
made up panels for rear quarter out of 1/8th steel have some trimming to do yet but they are close.
Old November 13th, 2011, 05:39 PM   #148
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
so next up is sheet metal work on wheel tubs and floor where dana 300 pokes in on pass floor board. then make new cross member for front links. picked up a used fuel cell today working on fitting stock pump and sending unit in it.
Old November 13th, 2011, 05:43 PM   #149
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
here you can see stretch and how much i took out of wheel well.
before
After
Old November 13th, 2011, 07:54 PM   #150
John D
John D's Avatar
Please show pics of how you do the wheel wells. Are they going to be shaped like stock or just square? have you seen the T&T Project Low Wagon over on NAXJA? That's what I am going to model my rear after.
Old November 13th, 2011, 08:12 PM   #151
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
huh never seen that one. just checked it out looks nice im doing same thing just moved axle back so i didnt cut into the door area i will keep that lip on there. but i will reuse the stock wells and put a pice in to take up the gap. ill post some pics in the next few days when i get going on them.
Old November 13th, 2011, 08:16 PM   #152
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
I did already remove the hump in the front wheel well like he did just havent sheeted it in yet. thats yet another thing on the list..
Old November 17th, 2011, 07:02 PM   #153
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
so i started on crossmember here are a few pic's
Old November 17th, 2011, 07:02 PM   #154
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
started with some 2x3 tube.
Old November 17th, 2011, 07:03 PM   #155
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
cut it out to lower the trans mount down.
Old November 17th, 2011, 07:04 PM   #156
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
welded on a 1/2 plate for mounting
Old November 17th, 2011, 07:07 PM   #157
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
here is test fit between frame rails. fits great is about 1/2 inch above frame so i will have a flat belly plate for a skid.
Old November 17th, 2011, 07:07 PM   #158
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
I like the stance!
Old November 17th, 2011, 07:09 PM   #159
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
welded up link brackets i will have 8" seperation at the axle between links. should handle close to what the stock short arm was.
Old November 17th, 2011, 07:13 PM   #160
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
thanks.. trying to keep it low.
Page generated in 0.36206 seconds with 83 queries
