One Ton XJ BUILD (Updated wheeling PIC'S) - Page 10 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 4th, 2011, 01:46 PM   #181
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
bbrancheau is offline   Reply With Quote
Old December 4th, 2011, 01:49 PM   #182
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Also sandblasted and repainted my BDS coil's
Old December 4th, 2011, 01:54 PM   #183
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
I still have something's to do to crossmember (some Plate work) but this allowed me to take measurements for my links.
Old December 4th, 2011, 08:00 PM   #184
BDR
Looks good. Curious, what did you paint the coils with? Just rattle bomb?
BDR is offline   Reply With Quote
Old December 4th, 2011, 08:50 PM   #185
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
I really like the implement and tractor paint. Enamel, I think it holds up better and keeps a shine. But it takes like two full days to dry.
Old December 4th, 2011, 09:06 PM   #186
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
I know I have been jumping around some. I have to do this to get things done as I make parts or they come in. I have a new idea for my rear wheel tubs as well. Have to wait and see if it all pans out.
Old December 11th, 2011, 07:13 PM   #187
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
steering links done and track bar made 1 1/4 DOM 1/4 wall, 7/8 himes.
Old December 11th, 2011, 07:14 PM   #188
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Rod ends take a 3/4 bolt
Old December 11th, 2011, 07:23 PM   #189
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Welded the tubes...slow with high heat, Pre-heated all cast welding.
Old December 11th, 2011, 07:25 PM   #190
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Installed my Ampco bronze bushings these take the place of the needle bearings.
Old December 11th, 2011, 07:29 PM   #191
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Burned in the lower link mounts.
Old December 11th, 2011, 07:31 PM   #192
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
After welding tubes and lower link mount on Passanger side i would heat location where it was cast over and over less heat each time then i wraped it up for final cool down.
Old December 11th, 2011, 07:34 PM   #193
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
My 7075 aluminum Links will be here tomorrow its great having a brother Inlaw that has a machine shop..
Old December 11th, 2011, 08:44 PM   #194
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
I have to do some mod's to the trac bar mount on the frame i can cut 3" off it because i do not need the other holes. Also im going to relocate my front shocks down about 4" because im to cheap to buy new ones . Ill save $ for the nitro shocks when (if) the time comes. next i will get axle back under the jeep, work on the fuel cell mod's, Wheel tubs for the rear, Mount battery in back, then i get to try to snake an exhust in this thing.
Old December 12th, 2011, 06:10 PM   #195
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
7075 links right and left joints
Old December 12th, 2011, 06:10 PM   #196
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
38" eye to eye
Old December 12th, 2011, 10:07 PM   #197
branch92
Only in a jeep
branch92's Avatar
i cant wait to see this thing done
branch92 is offline   Reply With Quote
Old December 15th, 2011, 08:44 PM   #198
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
got the links in
Old December 15th, 2011, 08:45 PM   #199
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Old December 15th, 2011, 08:45 PM   #200
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
Page generated in 0.45787 seconds with 83 queries
