need 220v help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 4th, 2010, 11:14 AM   #1
xj nut
maxin out the 30
xj nut's Avatar
Default need 220v help
well im pretty set on buying a welder with my tax returns, so i have decided on the hobart handler 187. the thing is the garage doesnt have any 220 outlets. what do i need and need to know before i have somone put 220 in?
i can supply info as needed.
xj nut is offline   Reply With Quote
Old February 4th, 2010, 12:37 PM   #2
jonzer12
How many amps is the service to your garage now? If you garage panel has 220 you can add a 220v plug in minutes. I ran 60 amp service to my garage and did everything myself.
Wire and panel cost me a fortune.
If you are hiring someone they will be able to inspect your home panel and tell you how much you can run to your garage.
All you need to do is look at the equipment in your garage and decide what your mandatory requirements are.
jonzer12 is offline   Reply With Quote
Old February 4th, 2010, 01:47 PM   #3
Not much you need. Is this just as a normal house/attached garage?
Your house already has 220, so you just need to run it to the garage.
Do you just want to run an outlet for your welder, or a complete sub-panel for your garage?
You will need 2 adjescent spaces in your houses main panel to run a 220 outlet, or feed to a sub panel.
Your welder willl likely only require a 20amp service, but consider running wire size larger for 40-50 amps. The welders do seem to run better when they have larger wire to handle inrush surge, and if you want to run something larger in the future, you'll have the wiring. Nice if you need to back-feed your house panel with a generator....
I wouldn't think it'd cost you a 'fortune' to run a sub panel in the garage, I did a 60 amp panel in my last garage, not much money.
Old February 8th, 2010, 07:02 PM   #4
cruiserjg
dodge man
cruiserjg's Avatar
I will sell you the power mig215.
Then we need to teach you how to weld.
cruiserjg is offline   Reply With Quote
Old March 21st, 2010, 06:54 PM   #5
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
I know this is a older post, but..
I just spent $250 for everything to run a 100amp service to my garage..
I'm also planning to get a Hobart Handler 187..
nick_n_ii is offline   Reply With Quote
Page generated in 0.18766 seconds with 38 queries
