eletrical problem with dash? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old February 3rd, 2010, 09:07 PM   #1
don4life
don4life's Avatar
Default eletrical problem with dash?
GOTTA LOVE NEW/OLD VEHCILES!!
ok just bought 95 k2500 suburban and it only shows around 10-12 volts on the voltage gauge, but i get over 14 at the battery, also the fuel gauge moves around like its possesed and now the speedometer works then doesn't work the starts to work and then doesn't work at all.
So i wanted to check and see if anyone has had same problem, is it electrical or just need to change the dash cluster out??
don4life is offline   Reply With Quote
Old February 3rd, 2010, 09:10 PM   #2
clarkstoncracker
lol
clarkstoncracker's Avatar
Check from chassis ground to pos terminal on the battery. Or test resistance from the negative on the battery to the chassis.
Old February 3rd, 2010, 10:51 PM   #3
86scottsdalek10
86scottsdalek10's Avatar
i had a 1990 sierra that had a bad chassis ground that threw off my voltage but the gas gauge was a sticking float on the sending unit
86scottsdalek10 is offline   Reply With Quote
Old February 4th, 2010, 12:59 AM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
x2
Had the same issue on 90 k1500, was a bad ground. I would recommend checking/cleaning all ground attachment points. Replace any bad cables with 4ga wire if needed. Took care of my problem.
Old February 4th, 2010, 01:45 AM   #5
Tomahawk715
Tomahawk715's Avatar
Is this with it running?? Seen gauges fruit out like this when the alternator was on the way out too.
If not prob is your ground somewhere.
Tomahawk715 is offline   Reply With Quote
Old February 6th, 2010, 11:07 AM   #6
don4life
don4life's Avatar
thank you guys very much!! Just added a ground from motor to frame and everything seems great it even feels like it runs alot stronger!!!
Page generated in 0.21155 seconds with 41 queries
